I have a problem where XL freeze's whilst using the latest Wyse model C101e on firmware 7.0.0_30 The Servers that the terminals connect to are a mixture of HP BL460 \ 490's. The server OS's are Windows 2003 SP2 R2 with Xenapp 4.5 installed. We have a mixture of our Xenapp servers being physical and virtual. The virtual servers are hosted on XenServer 5.6. Info from Emma about the terminal: Firmware (new) 7.0.0_30 Firmware (current) 6.5.0_34 Model not working: C10le Model working: S10 All this is running under citrix ! Can you help ...
  • 47 Answers
SOURCE: sn 3250 router problem
Ok, I'm confused... are you sure this isn't router that you're mentioning isn't a SAN Switch? A StorageTek/Brocade 3250 switch... and this is a StorageTek Scalar 100 Tape Library with Fibre aware LTO Drives. The Library Users Manual can be found at http://downloads.quantum.com/scalar/S100/omS100UsersGuide.pdf. Switch information can be found at http://www.storagetek.com/products/product_page2304.html. I'm not a Sun guy, so I would suggest that you contact them to find out which versions of firmware for the switch that they have certified. With HP, there are certain versions of firmware that they certify with HPUX... and specific versions of HBA drivers that work better with HPUX as well. If it is, in fact a Brocade 3250, I would suggest that you start with a "switchshow"... figure out which port drive 4 attaches to... do a "porterrshow #" (# represents the port found) to see the port error statistics... you want to check the loss of signal and link failure count. I would do an "sfpshow #" to see the status of the transciever as well. Let us know.
Posted on Sep 14, 2007
  • 17 Answers
SOURCE: router cannot connect to servers
The ports that need to be open to connect to the game server are fowarded to your machine and can't be used by another connection. You'll have to release the ports with the router configuration utility in order for another machine to use them. Better still see if you can find out what range of ports the game can use and forward a different set to his machine. Then you can both connect at the same time.
Posted on Jan 18, 2008
stif_NEC
  • 441 Answers
SOURCE: A lot of problem WRT54GR with DHCP, gmail, hotmail, google earth, deezer.com ...
Try settings up the MTU to manual.
1500/1400/1300 for cable connection.
1492 for DSL. if this may not work then yes, you need to upgrade the firmware.
Posted on Aug 22, 2008
  • 257 Answers
SOURCE: I just got a Linksys WRT160N router. I cannot
you are right, need cd for you lan card for it to work right,,but if you dont have it go to linksys web site and download the files you need
Posted on Aug 12, 2009
lifebyguitar
  • 57 Answers
SOURCE: My F5D7230-4 Belkin Router Virtual Servers power forwarding broke
Hi there!
Have you checked the Windows Firewall settings? If it is On, try turning it off and attempt the connection with RealVNC. If the problem persists, try adding an Exception to the Windows Firewall, just as an added troubleshooting measure.
Click Start, navigate to Control Panel, double-click Windows Firewall, and open the Exceptions tab. Look for a RealVNC entry. If you don't see one, click the "Add Port" button, type RealVNC as the entry name, and 5900 as the port number. Select the TCP radio button, click OK and then OK once more. Attempt the RealVNC connection again.
I hope this helps! Feel free to reply with results or further questions.
Posted on Aug 22, 2009
I have a wyse winterm v30 thin client. what steps will it take in order to reload the firmware?
you can download this pdf guide from
https://support.wyse.com/OA_HTML/cskmbasicsrch.jsp?jttst0=6_23871%2C23871%2C-1%2C0%2C&jtfm0=&etfm1=&jfn=ZG455B66622DEA31A7AE70467E3EBEC537FE9176B1484EFD6E483B952B0ED1CF6F10611204C7B33B20AA233809D7249C41FE&oas=etuN3Cl3pQgYaOxTZDlD7w..&categoryId=10820
this will show you the steps to do a USB firmware upgrade.
Mar 20, 2011 | WYSE Winterm V30 Thin Client - Thin Client...
Wyse S30 power settings
You can check the settings in the bios (password will be "Fireport") I dont think there is anything in there that would trigger this.
Is there a screen-saver option in the control panel for the device? If so, see if it is set. If not, then try using the Wyse website to update the terminals OS to the latest. This will hopefully solve the problem. It might just be an incompatability with the older OS version.
Jun 22, 2009 | WYSE Winterm S30 Network Terminal
Connection reset by peer
is this a citrix environment? have you just applied a rollup pack to your terminals?
You need to speak to Wyse!
Apr 27, 2009 | WYSE S10 (90210501) Network Terminal
Issues with Keys on Wyse and Citrix
Do you know what image version you are using on this terminal? It might be best to download the latest firmware for the device, and upgrade.
You can download WYSE imaging tools, and images from their website for free.
http://www.wyse.com/serviceandsupport/support/downloads.asp
You can also download ICA client upgrades for your unit from there too. This will hopefully solve your problem.
Nov 26, 2008 | WYSE S90 THIN CLIENT KB/MSE XPE...
Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
I have Wyse V50L termimals that cannot connect to Terminal Server 2008. Connections from XP Remote Desktop Client work fine. The server is configured to not use Network Level Authentication. The...
Have you tried the latest V50L firmware version? There was a major revision lately?
Oct 25, 2008 | WYSE Computers & Internet
USB printer crashing thin terminal when 'out of paper"
Wyse ThinOS firmware updates are chargable, or you need a maintenance contract in place for major firmware changes.
Going from 6.1 - 6.2 would be chargeable, but getting the latest version of the firmware version you are currently on should be free.
You are best off talking to your reseller or Wyse
Oct 20, 2008 | WYSE S10 (90210501) Network Terminal
Internet Explorer Addon
Re-image the device with the latest firmware from the Wyse site.
This should enable you to use the latest IE addon without issues.
Aug 22, 2008 | WYSE Winterm 3150SE Network Terminal
Getting connected
Build a Windows server with DHCP and DNS and install Terminal Services. Open config on the winterms and setup the RDP client. Follow the prompts, it's pretty straight forward.
Term Service requires license after 90 days AFAIK, so you better have a plan by then.
Thats the easiest way to setup and connect, it is a far from complete solution, though.
I would suggest you google upgrading the winterm firmware using FTP, the older firmware is poor and slow.
Otherwise, these are great little termianls that will last forever and work well.
Mar 17, 2008 | WYSE Winterm 3350SE Network Terminal
Wyse S10 Power UP issue after hung-up.
pull out the power cord for 5 minutes than put back in and turn on
Jan 29, 2008 | WYSE S10 (90210501) Network Terminal
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
