Question about Sony VPL EX7 LCD projector 2000 ANSI lumens XGA (1024 x 768) 43 VPLEX7 VPLEX7 Projector
I have problem. LCD projector Sony XGA VPL-EX7, its work and result projection in screen/wall is good but only work 1-2 minutes and off then power off/shut down. After start again its only work 1-2 minutes and same again continue like that( i am sorry i still learn english) yani-indonesiav
2 Suggested Answers
SOURCE: i have problem. LCD projector
pudiera ser que los ventiladores que tiene no esten trabajando por lo que calienta y se proteje debe serrevisado por un experto
Posted on Oct 05, 2010
Sony vpl dx 100. Why does it indicate frequency out of range when I connect my VGA cable to the the port?
Sony VPL DX 100 is a native XGA projector [1024x768]
so if u connect to a PC that has higher resolution than XGA , it will not be able to project and will show u out of range .
you will need to reduce the screen resolution in your resolution settings to XGA and the problem will be solved.
On a Laptop however, the graphics card should automatically identify the native resolution of the projector and adjust the screen resolution that is being sent from the graphics adapter.
you can also repalce the VGA cable and check if the problem gets solved as a broken pin or cable internally can also result in a similar problem!
Jun 05, 2015 | Sony Office Equipment & Supplies
Where will i get air filter foam/cloth
i am also looking for this answer, it looks like people try to make a quick buck on ebay selling this http://www.ebay.com/itm/NEW-PROJECTOR-AIR-FILTER-FOR-3M-Projector-FIT-FOR-3M-PROJEDTOR-AIR-FILTER-/180827230857?pt=US_Remote_Controls&hash=item2a1a249289
But im going to just go buy some thin foam type stuff and keep my old frame and glue or attach the new stuff to my old air filter frame and that should take care of it.
GOOD LUCK
Jun 12, 2013 | Sony VPL EX7 LCD projector 2000 ANSI...
Want to reset sony vpl ex7
where it the RESET located? I do not have any on my VPL-EX7
Jan 02, 2012 | Sony VPL EX7 LCD projector 2000 ANSI...
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
Jun 28, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
I got flikkring picture display with my sony vplex7 projetor
Try a different source ie a laptop and see what happens.This sounds like a source problem.
May 03, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
I can't get marry my laptop to the projector the manual is lost. had to buy new usb cord and still can't get the projector to play my video
the projector needs a vga cable or composite connection to show the display from the laptop , it will not work with a usb lead
If you found this info useful please vote for me
vga to vga lead looks like this
a composite lead looks like this
Mar 30, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
Hello, good day. My problem is relationship my sony xga vpl - ex7 not turn on. Only lighting the lamp/cover.
Either lamp is dead/ broken in projector or lamp cover is not fixed properly (its located at bottom side)
Please check lamp and replace it if its broken and make sure lamp cover is fixed back on its location securely after lamp replacement/ checking.
Thanks.
Jan 24, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
How to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Jun 01, 2009 | Sony Office Equipment & Supplies
Sony VPL EX7  LCD projector  2000 ANSI lumens  XGA (1024 x 768)  43  VPLEX7 VPLEX7 Projector Logo
163 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
