Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Galaxy refrigerator wot cold
I have a galaxy fridge model # 106.56502400 that is no longer cold. Can anyone help me?
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Fidge is not getting cold wot temperature is it suppose to be set at
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Prestige Appliances PRT295FFCS (9.3 cu....
GE model tbx14sisdrwh fridge. freezer works fine but the fridge will only cool to 50 degrees can anyone tell me the problem thank you.
heatman101
Aug 13, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
The defrost light/button in my fridge is on and the fridge is not cold anymore the freezer seems fine. wot should i do?
heatman101
Apr 16, 2011 | Refrigerators
After a bottle of gin broke spilling it's contents in the upper portion of our bottom freezer Amana Model BRD18V2S, The refrigerator no longer gets cold, we have aired out the liquor fumes and although the...
My wife posted the information below and I would like to add more to the story: We have two identical Amana Bottom Freezer Refrigerators, Model:BRD18V2S installed in our Kitchen. Both fridges are in an alcove and stand next to each other. One fridge is used as the beverage fridge and othe other is used as a food fridge. At about 10pm she noticed that an entire bottle (600ml) of Gin had cracked and emptied into the refrigerator section of the fridge used for beverages. We do not know how long the spilled gin was in the fridge. She mopped it up and we went to bed. At 7am the next morning, the beverage fridge and its freezer were showing 71 Degrees F. and everythind including the ice had melted. (We have aftermarket external temperature gages that show the fridge/freesor temperatures) The food fridge uninvolved with the gin spill was reading 68 Degrees F
Sep 17, 2010 | Amana Refrigerators
Hopoint fridge freezer model ff78p - fridge is not cooling
check the damper door vent between the freezer/refrigerator compartments and make sure this door is opening and closing as you adjust the cold control in the refrige section,it may have a diverter cover on it but you should feel cold air flow in this area even if its only open part way,then remove this cover and check that its not iced up if so use a hair dryer carefully and deice it,then try the control and see if it opens and closes as you adjust the cold control in the refrige
Mar 27, 2010 | Refrigerators
Common complaints
I found a few, and they're easy to get to. At the top of this page, under the FixYa logo, click on the underlined blue bar that says '25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water'. This will direct you to a page for Galaxy fridges with these features. Scroll down to see the complaints.
Best regards, --W/D--
Aug 08, 2009 | GALAXY Microsystems 25.4 cu. ft....
Refridgerator and freezer no longer cold!
Try disconnecting the fridge for a few minutes and then listen for the compressor to come on not just the fans.
Jul 02, 2009 | Refrigerators
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Jul 24, 2008 | Refrigerators
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
108 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
