Question about HP LaserJet M1522n MultiFunction Printer
Printer stays on for only 5 to 7 minutes then switches off
I bought two motion sensing diecast lanterns model HB-4190 series, SKU 248-593 and the instructions are hard to understand. To make it easy tell me how to set the device if I want it to come on only if...
Hello Gerald. Each switch has a function. the the test-1-5-10 allows you to set it to test or an on period of 1 or 5 or 10 minutes. The off-3-6-dusk to dawn allows you to turn it off completely, operate from dusk for 3 hours, operate from dusk for 6 hours or operate from dusk to dawn. By operate I mean turn on and then stay on for the number of minutes you set it to with the other switch.
what's nice about the test setting is that with it allows you to check and b sure that the light will come on during daylight by setting the one switch to test and the otner to any setting but off.
If you leave the 2nd switch set to off the first switch will not allow you to test it.
Joe
May 22, 2011 | Garden
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
Printer won't start
1. completely unplug power cord from wall socket,
2. unplug power cord from printer
3. unplug printer cable completely from computer
4. unplug printer cable completely from printer.
5. let printer stay disconnected for approx 1 minute
Now securely:
1. reconnect the printer cable to the printer.
2. reconnect the printer cable to the computer
3. reconnect the power cord to the printer
4. reconnect the power cord to the wall socket
turn printer on
You may find that a connection has simply worked itself loose over time.
Mar 29, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
When trying to copy a document the machine will go in the warming up mode and stay and will jnot copy.
turn off the printer and let it set about 5 minutes and turn back on. It will print after you do this.
Jul 08, 2009 | HP PSC 950 All-In-One InkJet Printer
Toner indicator light stays on even though it has been changed. There are no loose parts left in form the toner cartridge used before.
I just had the same problem. We have several of these in our office, but switching toner cartridges made no difference. Then I saw this site: http://www.oasis-imaging.com/images/pdf/cart_inst/TN580.pdf
I did steps 14-16, which takes 5-10 minutes. I put the toner back in the printer, turned it on, and it works perfectly now. Give that a try!
Apr 21, 2009 | Brother HL 5250DN Laser Printer
Eror code 3-380 System Fault problem
Whenever switchon my Dc12 The mahinc ready within 5 minutes and final stage it shows the eror like "System Fault" error code 3 -380 Switch of your printer and on. How can I solve it.
Oct 15, 2008 | Xerox DocuColor 12 Color Copier
HP LaserJet M1522n MultiFunction Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
