Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
WHIRLPOOL THIN TWIN STACKABLE LTE5243BW2
I HAVE THE BOTTOM WASHER PANEL OFF AND THE TUB IS SITTING TO ONE SIDE AND I CAN'T GET IT TO SIT RIGHT,THE 3 SHOCKS AND 1 SPRING LOOK LIKE THERE IN PLACE,THE SHOCKS HAVE A RING JUST SITTING ON THE BOTTOM OF THEM AND I DON'T KNOW WHAT THERE FOR,CAN YOU HELP ME?THANKS-MIKE
  • MIKE major May 29, 2008
    BOTH BACK TOP OF FRAME AT HOLD SHOCK RUSTED OUT,USED WASHER ON BOTH SIDE TOP AND BOTTOM IT WORKS GREAT NOW
5 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: HELP! My Whirlpool Thin Twin Dryer only works in Permanent Press sitting-buzzer goes off in all others
Replace the timer/control board
Posted on May 26, 2008
IFIXALL
  • 868 Answers
SOURCE: thin twin
on this  problem one of 2  the Shocks have pulled a part (seperated),possibly even broke off.After removing the front panel ,you'll see that on each side towards the rear of machine you have a shock ( similar to a car) arm starting from the base and angling upward where it meets the tup.Look for the seperation there and then let me know and I'll be happy to guide you through this.
Posted on May 28, 2008
huuum
  • 750 Answers
SOURCE: Repair manual for Whirlpool twin thin stackable LTE 6234?
Hello BUNNYLIB5
Welcome to Fixya
You said, Great website. Thanks so much for all the info. Where can you download a user manual for my Whirlpool LTE 6234? Mahalo, Lee.
Here is the whirlppool site
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm
=LTE6234DQ&siteCd=WHRCOM
Posted on Oct 03, 2008
  • 10865 Answers
SOURCE: The front panel on my stackable thin twin
Hello. generally these panels are held in place by metal clips. Gently pull the panel out a bit more and look behind for these clips which just go into holes in the frame. Regards, Joe
Posted on Feb 24, 2010
I need to replace lid switch on Whirlpool Thin Twin washer/dryer unit. How do I get the switch out and the new one in
The 3 screws across the front of the slanted panel need to be removed, then the panel. At the left and right rear of the main washer top are 2 5/16" screws, these need to be removed, there is a loose fitting steel clip through a slot on the main top these are holding down, when the 5/16" screws are removed slide the entire top forward and it will release from the front fixed clips. Unplug the lid switch unit and the main top can be set aside to replace the switch. Pleazer Appliance...
Jan 14, 2015 | Whirlpool Thin Twin Washer and Electric...
Thin twin tub loose
you will need to remove the front panel of the washer,there are 3 spring suspension rods below the tub and either one or more of these springs are disconnected from the tub or broken
Dec 07, 2012 | Whirlpool LTE6234D Top Load Stacked...
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin YLTE6234DQ2 washer is leaking water from the bottom. I need to remove the front panel to see what the problem is but can't seem to get it off. I have looked at suggestions to push in...
have you looked near the bottom of the front panel near the floor,there are 2 or 3 screws located at a 45 degree upward angle(to hide them from view) so they dont show,remove these and the front should hinge upward like an auto hood and the clips near the top should let go when its raised far enough upward
Apr 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
The barrell has come loose on my thin twin stackable washer/dryer
The struts, shocks, springs...they are called different things depending on who you speak to. Apparently on the heavy duty thin twin stackable units they are all bad and last for about 13 months just after the manufacturers warranty, this is common knowledge among Whirlpool technicians and even the replacement parts that are being installed are not performing for the lifetime they were designed. I have contacted a repair service and they are scheduled for the middle of next week and over the phone he ballparked the estimate at about $300.00.
May 15, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool thin twin
YOUR SHOCKS ON THE TUB HAVE RUSTED AN THE TUB HAS FALLEN IN,YOU CAN TAKE THE TUB OUT AND USE WASHERS ON TOP AND BOTTOM OF SHOCKS TO FIX IT,THANKS-MIKE
May 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
311 people viewed this question
Dan Webster
Dan Webster
Sal De
