Question about Makita 12 Volt Cordless Drill/Driver Kit
Charger for makita 9.6volt 6095d not working - Makita 12 Volt Cordless Drill/Driver Kit
  • 30 Answers
Revisar las terminales del cargador que hasen contacto con las del taladro yestas tambien porque puede ser que esten oxidadas y linpiarlas con limpia contactos y con lija n400 o mas fina
Posted on Oct 05, 2010
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
Sep 20, 2013 | Makita Drills
Problem taking batteries out of older Makita drill (6095D) to recharge/replace them.
there is a clamp on the bottom that has to be unlatched and the battery should just pull out of the bottom, unless it is stuck by corrosion and then you might have to "TAP" gently to remove. You can download a breakdown of this tool at makitausa.com to see what I am talking about.
Jun 26, 2011 | Makita Drills
MAKITA LXT BL1830 18V LITHIUM-ION 3.0AH BATTERY
If the charge count on the batteries is under 300, Makita will replace them. Makita has a known defect in this battery that causes the battery to shut down before it is dead. So as of now they are exchanging ones with low use.
If they are truly defective and makita won't replace, you have to open them, find the dead cell or blown fuse, and replace. Search youtube makita battery for a video on repairing this battery. But once the red and green lights on the charger flash, the the battery can't be charged on a Makita charger -- it's been locked. So use a third party charger.
Apr 18, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a li-ion Makita BL1830 18V 3.0Ah battery that can't be charged...when on the charger the bottom two lights flash red..it will charge my other battery, so it doesn't seem to be the charger
Sorry Mate your battery is dead...
The makita lithium batterys dont like getting worked hard quickly.
There is a chip in them that recognice each battery to each specific charger. Try another charger. This has not worked for me. Try anyway
Nov 01, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
What is the procedure for removing the chuck from a makita 6095D 9.6v drill?
Most chucks use a tapered shank that allows you to remove it with a good tap on the bottom. Other chucks have slots in the slots in the shaft that allows you to tao it off with a wedge type key. You could always use a dent puller and chusk on the screw.
Good luck, Jack
Aug 21, 2009 | Drills
How to replace forward and reverse switch on a Makita model 6095d cordless drilldriver
If you are mechanically inclined you should have no problems but if not this is involved. First I would recommend going to the Makitatools.com website and on the right side type in your model number and look at a breakdown for this unit. To start with you have to remove the chuck, then the collar with the 2 springs under it and then remove all screws from the housing separating it carefully so none of the parts jump out. The switch is polarity sensitive so make sure of the wiring. If you still want to tackle this let me know and I will go into more detail on this. Good luck
Apr 08, 2009 | Makita Drills
Makita 12 Volt Cordless Drill/Driver Kit Logo
197 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
