Question about Dual Marquant TIS Audio Amp 700 Watt 5 Channel Bridgeable Amplifier
I need to know which color speaker wire go where I have t510pk 700watt 5 channel amp and on the converter has 9 wires I don't remember what order they go in someone please help
Grey = F/L-
Pink = F/R-
White = R/L-
Yellow = R/R-
Purple = F/L+
Red = F/R+
Green = R/L+
Brown = R/R+
Black = GND
Posted on Dec 07, 2010
Wiring help for realistic 5 band equalizer cat.no.12-1963 don't know year or model of unit it has no wiring label on it. has 3 gray wires, 3white wires,3 green wires, one black wire,one brown wire....
the 5 thinner cables goes to positive lead of each speaker from the radio (input to amp) the red one to battery.You will not use the negative led for the speakers from the radio. The remaining coarse ones goes to the speakers (each pair same color to a speaker) and the red one feed radio positive led. Black is ground.
Jul 03, 2011 | Car Audio & Video
Radio wire colors
1994 Volvo 940 Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Yellow
Left Front Speaker Negative Wire (-): White
Right Front Speaker Positive Wire (+): Gray/White
Right Front Speaker Negative Wire (-): Gray
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/Brown
Left Rear Speaker Negative Wire (-): Yellow/Green
Right Rear Speaker Positive Wire (+): Green/Brown
Right Rear Speaker Negative Wire (-): Green
Hope helps (remember rated this) TY for use Fixya.
Jun 03, 2010 | 1994 Volvo 940
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
Need TIS t510pk wiring help
Grey = F/L-
Pink = F/R-
White = R/L-
Yellow = R/R-
Purple = F/L+
Red = F/R+
Green = R/L+
Brown = R/R+
Black = GND
Jun 06, 2009 | Car Audio & Video
Need to know how to wire the speaker mono?
Bridge should be made positive left channel + negitive into - right channel but make sure the amp can take the speaker impedance load or you will trip the amp or cook it if you over load it.
PW NW You may also need a choke for correct frequencey response
May 11, 2009 | Car Audio & Video
Adding line out inputs for RCA cables to amp
Hello ssmotorcity,
Here's a link to modifiedlife's Durango page showing the wire colors.
http://www.modifiedlife.com/2005-dodge-durango-car-radio-stereo-audio-wiring-diagram/
If you are adding a LOC for an amp to drive a sub, you are probably better off using the rear speaker wires, the last four wires shown on the listing. If you are adding an amp to drive all 4 channels, then of course, you need to convert both fronts and rears. The simple method is to tap directly into the appropriate wires and connect them to the line converter. If you do not want to tap the wires, you can purchase aftermarket wiring harnesses that are made to plug directly into your vehicle radio and/or the vehicle wiring harness. The Metra part number for a stock radio harness is 71-6502. It plugs into the radio and provides pigtail connections for power and speakers. There is, of course, a harness that plugs into the vehicle harness itself, allowing you to make the connections without any cutting or tapping of the original wiring.
Hope this helps.
Apr 16, 2009 | Car Audio & Video
How do I connect a line output converter to my factory head unit
depending on the type of line out converter that you have you simply just take the speaker wires coming from the head unit (you must know the color codes for the wires or you can do the process of elimination by pulling off the door panels and and viewing the colors and matching them at the wire harness behind the head unit). Pull out electric fuse for radio so you dont blow it while hooking up the wires. After you have done that just connect the speaker wires coming out of the head unit to the line out converter this will pre-amp your signal. After you have done that step on the other side of the loc you will have to connect and run rca audio cables to the back of your car to hook into your amplifier. The last step is to splice the power and ground wire coming from the wire harness and connect the radio power wire and loc power wire to the main power wire and then connect the radio ground wire and the loc ground wire to the main ground wire. Test and your done with the loc.
Aug 12, 2008 | 2008 Chevrolet Impala
Need to get wiring diagrams
1988 Dodge Ram Charger Car Audio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange
Car Audio Front Speakers Size: 6′ x 9′
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
pls rate
Jun 23, 2008 | 1988 Dodge D-Series Pickups
I need the color codes for rear speakers in a 1996 thunderbird lx.
positive wire is red, yellow wire is positive on ignition okey for the speakers remember the solid color like green green w/ black line is negative follow the other coding w the solid colors
Apr 12, 2008 | Pioneer DEH-P6800MP CD Player
Bose 901 speakers the wiring inside
- Bose 901 Series I and II speakers have 8 Ohm impedance each.
- A row of 3 speakers in series gives you 24 Ohm.
- 3 parallel rows gives you finally 8 Ohm.
Front with 8 speakers (view from the rear):
(1) (3) (5) (7)
(2) (4) (6) (8)
Rear speaker is number (9)
Row 1: -(1)+ -(3)+ -(7)+
Row 2: -(5)+ -(9)+ -(2)+
Row 3: -(8)+ -(6)+ -(4)+
Oct 30, 2007 | Bose 901 VI Main / Stereo Speaker
Dual Marquant TIS Audio Amp 700 Watt 5 Channel Bridgeable Amplifier Logo
122 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
