Question about Vacuums
Need a schematic for Sunbeam electric blanket with G85 controller.
  • 2,382 Answers
Hi, the schematics for the electric blanket are not readily available online maybe due to the company's policy just like some others that i know. You may try your luck by contacting Sunbeam on (800) 667-8623 to make a request for the schematics.
Posted on Oct 05, 2010
Dual control sunbeam electric blanket, one side is blinking 'E' have disconnected it several times, but still nothing. It was wotking fine the night before. The other control is working fine.
An error has occurred in your unit. Near the power or elsewhere find the reset button and press it. If you done it still error is blinking, check if you can the heater and thermostat of the blanket has a problem. Either a short or open circuit occur.
Thanks for asking.
Jun 25, 2011 | Vacuums
The one of the controllers for the electric blanket keeps flashing an "e". The other controller is fine. We switched controllers and the same thing happened. We have unplugged the blanket for...
I did some searching-- and I came up with this Linkedin page-- seems to have some information-- Let me know if it helped-
http://www.linkedin.com/companies/jla-home
Mack B
Jan 20, 2011 | Vacuums
Our westpoint home electric blanket, model 950, flashes 8 on one unit & can't be turned off. ELECTRIC BLANKET!!
Try pressing the power button and boost button at the same time. Then a C will flash and the setting you had it on before will show up. I think that was caused by pressing the boost button.
Dec 28, 2010 | Vacuums
I need a replacement cap for the water tank Sunbeam humidifier model swm5251
Official instruction from this device suggests to call Sunbeam consumer service at 1-888-264-9669 to order replacement accessories.
Nov 28, 2010 | Sunbeam Vacuums
I received this electric blanket as a gift and it will not heat up on either side. There is no light on the controls when I turn the blanket on. I need my blanket to work - it's like brand new!
Appears to be that the power is not getting to the temperature controllers. Suspect a problem in the wiring between the wall outlet (if not the wall outlet) to the temperature controllers. Look for broken plug at end of cord or a break in the cord between the plug and the controller. Last, you may have to look at the connections inside the temperature controller the power cord goes to in order to see if there is something loose inside. But do this with the blanket unplugged.
Sep 18, 2010 | Sunbeam Vacuums
How do I find the model number on my sunbeam heated blanket?
The model number should be on the back or bottom of one of the temperature control units.
Sep 15, 2010 | Sunbeam Vacuums
We have an sunbeam electric blanket model BL 0750 We dont seem to be able to programme it to heat up. Control lights are flashing
Hi. If you have a double or queen size blanket, switch the controls from one side to the other. If the fault follows the control, then the control is faulty. If the fault stays on the same side of the bed, then the blanket may be faulty. Most recent Sunbeam models have 3 years warranty. Once you've checked the controls, if it's under warranty call Sunbeam Customer Service on 1800025059 option 1 to report a warranty issue.
Otherwise: if the control is at fault, a new BL0750 has a recommended retail of $75.20. Get in contact with your local Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
but if all else fails email me as I'm happy to help!
May 25, 2010 | Vacuums
1957 Sunbeam Twin-Blade electric lawn mower shaft bushing
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=654762
Generic problem for all Vacuums
1957 Sunbeam Twin-Blade electric lawn mower shaft...
Posted by mower man on Jun 08, 2008
I have a late 50's series Sunbeam twin-blade electric lawn mower that I use regularly. The shaft bushing(s) on the left blade has worn out, and there's too much play for me to run it w/o ruining the machine.
It appears that the belt-run cog inside the housing is the part that is supposed to come off of the shaft to get to the bushings, but instead of a cotter pin or other fastener holding the cog in place, it looks like a rolled metal pin that may have been pressed in place.
How do I replace the shaft bushings so I can keep using this great vintage appliance!? I found a website that supplies parts for this model year, but no schematics or user manuals. Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. This website is for vacuums and you would need to contact a local lawn mower shop in the yellow pages, they are amazing about the way they can fix old lawnmowers.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
Vacuums Logo
463 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
