Question about NetGear (WG602MES) 802.11g/b Wireless Access Point
Can not connect netgear to wifi - NetGear (WG602MES) 802.11g/b Wireless Access Point
Car nt conect to iphone to share vidios
Posted on Nov 29, 2011
How do you connect netgear extension to router
This article provides instructions on how to wirelessly connect to your NETGEAR Wi-Fi Extender using manual setup after the NETGEAR WiFi Extender has been successfully connected to the Access Point (AP) and obtained a valid IP address.
https://kb.netgear.com/25504/Unable-to-connect-my-NETGEAR-WiFi-Extender-using-manual-setup?cid=wmt_netgear_organic
Feb 23, 2017 | NetGear Computers & Internet
My Netgear WN3000RP Wi-Fi Range Extender is not working since last night . please help
Try unplugging BOTH the repeater and the router, Then, plug the router back in and let it establish a connection. Then, plug the repeater in and let it reestablish the connection.
Feb 03, 2015 | NetGear Universal WiFi Range Extender...
Netgear streaming player
Sounds as if it has found an open Wi-Fi connection, but the device it is connecting to doesn't have an internet connection.
Make sure the Netgear player is connecting to your wireless network, and that you have a live connection to the internet.
Aug 30, 2014 | NetGear NeoTV NTV300
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
My phone does not connect to the wifi from the netgear mr8142v2 but this phone has connected to 5 other wifi networks. How do I get this to work?
Hi!
If it was working before, you only need to clear or delete the current wifi profile on your phone for the netgear router and just create a new wifi profile. Make sure to enter the corrent Wireless Settings specially the Security Key. It is case sensitive, sometimes that's the only problem why you cannot connect. You are typing an incorrect network key. You can also try to change the channel that the netgear is using. Power cycle can help you also. Just unplug the power on the back of your router for 30 seconds then try again.
Feb 14, 2011 | Motorola Computers & Internet
How do I connect my netgear router to my desktop internet to use with my laptop. Followed instructions but when cable is disconnect from my laptop I can't connect to the internet
First Connect the Desktop with Netgear Router with the Ethernet cable. Open the Netgear GUI and configure a Wireless Network. Once its configured, switch On the WiFi switch from your Laptop and try to connect your Laptop. Make sure your laptop has an in-built Wifi adapter, if it doesn't then you would need to buy an USB based Wifi Adapter.
Also if you want to use the Internet with your Desktop PC without being connected with the Netgear Router then make sure it has Wireless connection capability.
May 10, 2010 | Computers & Internet
My computer freezes when connecting WIFI adapter
Does this happen if you try connecting it into all USB ports? Try another USB port. Do you know if your USB ports are 2.0?
Mar 30, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Connection wifi problems with ds and netgear
it might be a WEP password which is located on the botom of the router.
Jan 03, 2009 | NetGear WGR614 Wireless Router
Netgear has strong connection but it doesnt connect
I think you may that the "Drivers" & OR settings for this WiFi adapter are not working correctly. What ya need to do is Install the "Drivers" & "Software" from the Netgear CD that came with ya device and set it all up per your manual. Here are a couple of links to help below.. mobileoffice.about.com/od/findingusinghotspots/l/blwificonnectio.htm www.microsoft.com/windowsxp/using/networking/expert/bowman_02april08.mspx Basically, ya install the drivers & software reboot, insert ya USB WiFi into ya USB port, if it then asks for "Drives" point it to ya CD... when finished then you should be able to "See" ya Access point etc.. and connect.. setting any protocols you wish..
Aug 23, 2007 | NetGear MA111 802.11b Wireless Adapter
NetGear (WG602MES) 802.11g/b Wireless Access Point Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
