Question about Philips 37MF321D 37 in. LCD Television
Not powering up right away
Green power light flashes for 10 - 20 minutes before finally turning on
  • 2 more comments
  • blindexperts Aug 29, 2008
    green power light blinks forabout 10 minutes andthen turns of...i push power again andgreen light comes on steady but tv still doesn't turn on...
    i keep pushing power button on remote and eventualy it does come on and works beautifully fo hours and hours...when turned off it will turn on correctly for about an hour...if left off overnight the green power light just blinks and tv doesn't start
  • cabannie Sep 06, 2008
    Same problem with out set. Green power light comes on, burns steady for several seconds, brightens and and then turns off. I have to push power again at least 3 times before the light finally comes on steady and then the TV will come on. Then it will work for hours and when turned off can be turned back on right away for about an hour. We also have a problem with the sound going out. Turn the TV off then right back on and the sound is back.
  • Anonymous Feb 20, 2009
  • miratessa Mar 07, 2009
    Same problem here!
    Problem Solver:
  • 13 Answers
This is a big problem with these tv's. Magnavox built them with undersized capacitors, and they blow. You have to open the back, remove the power supply and replace the capacitors numbered 2074 and 2081. This sounds like a real tech job, but read my other solutions, and you will see it is not so hard. Good luck.
Posted on Sep 30, 2009
My hitachi 1999 tv turns on but off right away has flashing green lights in back
If the flashing green lights are on the circuit board each is tied to a voltage from the power supply----likely damage is there but a 99 may not be economical to fix in 2012.
Nov 04, 2012 | Hitachi Televison & Video
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Green light flashing. no Internet access
Hi and welcome to FixYa!
We are going to reset your router as a first step, but this may just solve your issue in one shot if you are getting a green light already!
Turn router around;
Find the small pinhole usually located by the power cord;
Stick something like a paperclip in it and press down firmly for 1 minute;
wait until you see the lights blink and then go out;
Then; unplug the power cord from router for about half a minute;
Then, plug it back in.
This is the only way it will finalize resetting and it takes away your encryption;
resets your network name back to Linksys.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
Feb 06, 2011 | Linksys Wireless-G WRT54G Router
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
No picture, status light flashes yellow
display comes on works 15 seconds no power just leds green
Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
Wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Dec 16, 2008 | Toshiba Satellite A100-S8111TD Notebook
Powering on my tv
Dear smmmobil,
The problem lies with the SMPS (switch mode power supply ) of your TV. The smps board needs to be replaced.
ramesh22
Jun 15, 2008 | Televison & Video
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Philips 37MF321D 37 in. LCD Television Logo
354 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
