Computer says I need to remove software before reinstalling memorex 6142u scanner. Uninstall says it is uninstalled but when I run driver cd it tells me there is a previous installation that needs to be uninstalled.
  • 426 Answers
Uninstall the driver via device manager then make sure that all folders that the setup created are erased
Posted on May 28, 2008
Is there a driver for a memorex scanner 6142u for a visa operation system??
Try this liks :
  1. Memorex Scanners drivers - [ Traducir esta página ] Memorex Scanners drivers. Here are drivers for 7 models of Memorex Scanners. Driverscollection.com - One of largest free net library of device drivers for ...
    driverscollection.com/?V=Memorex&S=14 - En caché - Similares
  2. Memorex Scanner Drivers - [ Traducir esta página ] (Category: Scanner / Firm: Memorex / OS: Windows 95/98/ME/NT/2000/XP). 2. Memorex 6142U · Driver Download. (Category: Scanner / Firm: Memorex / OS: Windows ...
    www.driverskit.com/Scanner/Memorex.html - En caché - Similares
  3. Memorex Scanners Descargar de drivers Este sitio mantiene la lista de Memorex Scanners Los drivers accesibles para Descarga gratuita. Nada más que rastree nuestra base de datos organizada y ...
    www.nodevice.es/driver/.../Memorex/Scanner.html - En caché - Similares
Oct 03, 2010 | Memorex MEM48U Flatbed Scanner
Repeated message "windows cannot load OmnisuperCam" Followed instructions and reinstalled carefully twice. Photo Impression 6 loads and is active. OVT does not appear in control panel 'scanner and camers'
Hi.
This often happens because Image Copier installation must be done in exact order as described in the instruction manual. To fix the problem you need to uninstall and reinstall everything back in right order.Also remember to restart the system when required.
  1. Unplug the image copier
  2. Uninstall the driver (remove from installed scanners and remove driver files).
  3. Uninstall PhotoImpression6
  4. Restart your computer.
  5. Install the driver,.
  6. Restart computer
  7. Reinstall PhotoImpression6 software.
During installation ensure that you authorize the system changes when asked. If possible disable any security software.
If that does not fix the problem, then the registry must be cleaned of any entry related to the scanner software. This is rather difficult to be done manual. You can try doing a system restore to a recent date before the problem started after uninstalling everything, and then uninstalling again if needed (application and scanner are there after SR), and finally reinstalling everything in order. If that does not work you can try a registry cleaner or reinstall the system.
Here a copy of the manual.
Jun 22, 2010 | Computers & Internet
Error message reads: twain driver won't open
You need to uninstall and reinstall the scanner software, reboot between doing it.
Apr 01, 2010 | Memorex MEM48U Flatbed Scanner
Unable to install software on HP4370 Scanner. Although the previous software has been uninstalled a message appears stating that the software is already installed.
uninstall it completely ....even the driver ...cause if it is a auto-run install it sees that the driver and the printer it is still on ...or ..browse the cd ..and only click on the scanner software
first go to the control panel and remove the software from the add remove programs ...than ..restart the computer ..and than try only software for the scanner If it does the same...remove all drivers and software related with the printer /scanner..and run the complete cd again ...
Mar 24, 2010 | HP Scanjet 4370
Need drivers for a memorex 6142 usb scanner for the windows home vista program.
http://www.opendrivers.com/driver/215409/memorex-6142u-scanner-driver-windows-98-me-2000-xp-free-download.html try driver from windows 2000
otherwise no drivers availebel
Aug 24, 2009 | Office Equipment & Supplies
I have a memorex 6142u w/ no vista drivers???
This solution worked for me. I have 64-bit version of Vista. If you have 64-bit version of Vista this is the only thing that I have found to work.
What I did was used a different scanners driver for my Memorex 6142u. I used the Hamrick version of the Canon N1220U scanner driver. The best way to do this is to plug the USB cord into the computer. Vista will try and find the driver for you and fail. then go to device manager. It will say that it isn't working properly. Then fix the driver by selecting from the list of drivers that Vista has packaged with it.
Jan 26, 2009 | Memorex MEM48U Flatbed Scanner
I hae a memorex 6142u w/ no vista drivers???
Go to site http://support.visioneer.com/products/home/EOL/Memorex/
Download/save application file 6142. Check file properties, under compatibility select "run this program..." and choose Windows XP(Service Pack 2). if u do not have a vista option
Then run the program.
Good Luck
Powder Cord for Memorex 6142u scanner
The manual is available online at http://www.memorex.com/downloads/manuals/6142Scanner.pdf
The back page has the specifications for what kind of power cord you need, depending on what country you live in. The US one at least (120V/60Hz) is a very generic cord option and should be easy to find at any tech store. Good luck.
Jul 31, 2008 | Memorex MEM48U Flatbed Scanner
Computer can not find
do you have the software it came with [driver] if not go to the memorex website and download the driver there. if your saying you installed it already and its not identifying the scanner completely uninstall and reinstall. sometimes install have to be exact. uplug device and install software. dount plug the usb in until it tells you to. hope it works for you. let me know though im not clear on what the exact problem is
Feb 18, 2008 | Memorex MEM48U Flatbed Scanner
120 people viewed this question
jasbo
jasbo
