Question about Gigabyte GA-8IG1000MK Motherboard
Which type of ram does support this board - Gigabyte GA-8IG1000MK Motherboard
  • 487 Answers
Hi, this board supports the following.
DDR SDRAM
400MHz or 333MHz or 266MHz, the 400 is the fatest and the maximum amount of memory is 4GB
Posted on Oct 05, 2010
Additional 128 mb ram is not reconignies in ram slot
Remove all RAM, and eseat the new 128 board.
The new board MUST be :
128MB (1X128MB) PC100 NONECC UNBUFFERED 168 PIN SDRAM DIMM
If the criteria is anything but the configuration above, it will not work.
Also because of the type of memory, I am guessing the age of the board (or system) check to see what the max RAM is and see if your new board exceeds that amount.
Good luck.
Oct 08, 2010 | Gigabyte GA-6WMM7 Motherboard
What processors does the board support? What types of RAM does the board support? What is the maximum RAM the board can hold? If the board has a PCIe slot, what types of {CIe does the board use and how...
Hello
OK, at the link below you will be able to get all the answers to your questions.
Click HERE to navigate.
Please let me know if you need any further assistance.
Kind regards
Andrea
Sep 09, 2010 | HP Pavilion A6120N PC Desktop
PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard: RAM IS NOT WORKING. SUPPORTING RAM REQUIRED, CAN Y...
*********** supports DDR1 type Ram, you can easily get it from the market. Just ask the retailer to give you the DDR1 Ram, they will ask you how much memory of Ram you want. There are 256Mb, 512Mb, 1gb, 2gb, etc.. the more the better and this motherboard supports upto 2 gb, but some newer make of this motherboard miht have been changed.
May 17, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
I have 2gb of ram.but system detected 1 gb of ram
Make sure the board supports 2 gigs of ram, and make sure the board supports the type of ram you installed.
This info can be found either on the manufacturers website and/or the user manual that came with the board.
Mar 01, 2009 | Intel D102GGC2 Motherboard
Type fo Ram and Compatible graphic card
You can look up you mother board on the MSI support website. You wil need to know the CPU  socket type. Download the manual for the board and the RAM and recomendations or in the manual.
http://global.msi.com.tw/index.php?func=downloadindex
Jan 18, 2009 | Intel Motherboard
How can I convert 1 GB Ram into Mother Board 810 E?
YAS IS GOOD YOU CAN UPGRADE YOUR MEMMORY TI 1GB ALL YOU NEED TO DO IS GET THE EXACT TYPE OF WHAT YOUR MOTERBOARD IS USING eg IF YOUR MOTHERBOARD IS USING DD RAM GET 1GB DD RAM IF IT SD RAM YOUR BOARD USES THEN GET SD RAM. IT GONNA BE FINE WHEN YOU UPGRADE IT WILL PARFECT YOUR PC PERFORMANCE.
Nov 20, 2008 | Intel Motherboard
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Mother Board and And Ram
You dont say how much ram you have currently, so go to this site to inform of the type of ram you need. http://www.crucial.com/
Sep 20, 2007 | E-Machines eMachines Desktop PC
Gigabyte GA-8IG1000MK Motherboard Logo
42 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
