Question about Frigidaire Dryers
The dryer makes a squeaky noise and has begun "eating" clothes. They get stuck in the crack.
  • Frigidaire Master
  • 17,130 Answers
Both the faults are related to a poor alignment of the unit. You will have to remove and adjust the dyer to realign so as to reduce the gap as well as remove the squeaky noise.
remove the unit check the movement and set it to move with the slightest gap.
Posted on Oct 05, 2010
Dryer making chirpy squeaky noises then it stopped. Noise was intermittent
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Mar 10, 2015 | Dryers
How do I fix a squeaky dryer
DRYER MAKES NOISES.
The blower:
The bearings:
Oct 08, 2014 | Dryers
My danby dryer DCD 5505W is making a squeaky noise.
You need to change its Drum bearing and front rollers. Also replace its Drum glider/pads.
Jan 09, 2010 | Danby DCD5505W Electric Dryer
Dryer makes a squeaking noise when running
Check the following:
  1. Idler pulley - It keeps tension on the main drive belt and when it is worn, it can be squeaky and noisy. Replace then.
  2. Glides - Attached to the front bulkhead of the clothes drum for support. When worn, it can be noisy and squeaky.. Replace then.
  3. Rollers or wheels - They support the clothes drum. When they are are worn, you should replace the whole set of rollers at the same time.
  4. Blower wheel - It pulls air over the heat source through the clothes drum past the thermostats, then pushes it out the exhaust duct. It may wear out over time. If it is noisy, it may be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it.
Oct 26, 2009 | Kenmore 84152 Electric Dryer
Dryer thumps when running, clothes get stuck...
It always helps if you list the brand and model number in your post. I would look at the seam on the drum to see if the weld has cracked. (right at the front and / or rear of the seam.)
Jun 10, 2009 | Dryers
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
My dryer is making a very loud squeaky noise. Is is the motor or something else?
Not the motor if it's still working. The noise is coming from the bushing that hold the drum in place.
Apr 05, 2009 | Maytag Dryers
Nextra7 condenser dryer making squeaky noises
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Dryers Logo
140 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
