Question about Vacuums
I am looking for an empisal 406e overlocker user manual, indicating the settings for the types of stitching.
3 Suggested Answers
Tally Girl
  • 1129 Answers
SOURCE: I bought a 2nd hand
I haven't been able to locate a manual for this machine at first look. The only Empisal manual I did find was called "Expandamatic" at this site http://sewingonline.co.uk/empisal.html there is an image of the model. Or you could try www.2instructions.com or www.manualfox.com and see if they have something available to buy.
However, http://sewing.about.com/od/sewingmachineindex/bb/sewingmachines.htm this website gives lots of general information on sewing machines, how to use, basic threading up in a general way and other tips and tricks.
In general terms most sewing machines will have the following controls:
stitch length selector/dial - to choose length of stitch, usually goes from zero to 4, normal straight stitch would be 2.5.
Stitch width selector - early models only did straight and zigzag, so by adjusting this knob you would set how wide the zig zag stitch is. If your machine does other stitch combinations, then you would use this to set the width for those too. Again, probably ranges from zero (straight stitch would be zero) up to 4.
A tension dial setting to adjust the tension on the top thread, usually set to 5, but would range from zero to 10.
If your machine does anything more than straight and zigzag, then it would have some other dial or stitch selector or even a cam that you insert to get these other stitches.
I hope this helps you get started with your machine.
Posted on Jul 07, 2011
SOURCE: I have an Empisal Q2719/9300
Hi All
I have gone and uploaded the Instruction user manual for the dress maker 270d Please use the link provided to download the Instruction Manual. Have Fun :)
https://rapidshare.com/files/2244612243/Empisal_Dress_Maker_270D_Instruction_Manual.pdf
Posted on Sep 12, 2011
Empisal dress maker 270d
Sounds like your tension is vibrating off to a least tension position, When the machine does this again check your tension button. Hope this is the solution?
May 16, 2014 | Vacuums
Singer profinish serger
This sounds like a timing issue. You need a professional.
Jan 18, 2014 | Singer Vacuums
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
I have an Empisal Q2719/9300 sewing machine and need a manual to work out the stitches and how they work
Hi All
Jul 06, 2011 | Vacuums
I CANT THREAD MY 1034D BROTHER OVERLOCKER
If you cannot do this due to not knowing how, here is your manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_1034D_ENES_178.PDF
If you are looking for specific information on how to thread a specific looper or needle:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&
prod=hf_1034deus&Cat=53
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 08, 2011 | Vacuums
I'm new to sewing. It did not come with an operating guide and I find the stitch settings really confusing I would like to know how to set it to do a basic straight stitch for a simple dress pattern....
Look for the row of straight vertical lines. This is the straight stitch. There will also be a number dial for stitch length. Use a piece of scrap to find the length of stitch you want. Make sure you have the bottom feed lever or button activated. This will operate the textured plates that come up from underneath to move the material forward or reverse. Also, make sure you drop the presser foot lever before you start. Hold both threads, manually lower the needle to the first stitch starting point and use the pedal from there on. When you press the pedal, you can let go of the threads.
May 14, 2011 | Vacuums
Vacuums Logo
112 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
