Question about Whirlpool Refrigerators
I have whirlpool 220 classic refrigerator for last two week we find water outside front door of the refrigerator or below vegetable box . what is the problem
  • Whirlpool Master
  • 17,130 Answers
It can be due to an overflow of the drain tank that is at the rear bottom wherein when the defrost timer works , the frost condenses down to this tank.
It can also be a leak in the pipe line to the tank that causes the water to flow out.
It can be due to condensation within the door side that is flowing out., or even the collection tray leaking over , crust of frost falling out of the tray.
Posted on Oct 05, 2010
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
Whirlpool refrigerator double door fridge Ice deposits on the vegetables in summer season when placed directly in front of the cooling panel
Humidity is the most probable culprit. Verify if it is getting in
Examine the door rubber seals to ensure tight sealing. If rubber seals worn out, you may need to replace them
May 17, 2014 | Refrigerators
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a whirlpool mastermind refrigerator. from last 15 days water accumulates under the vegetable tub. why?
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 20, 2010 | Whirlpool Refrigerators
We have the Whirlpool Gold and get water the front outside dispenser but not to the icemaker. Is this something we can fix ourselves?
You probably have an issue with the water valve assembly (located at the lower rear of the refrigerator) or the icemaker.
Feb 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Small pool of water underneath Whirlpool fridge
There may be a water filter built in. Look for access lower front panel below door. recommend replace every year. They will leak when neglected.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice buildup in vegetable bins - otherwise OK Not model shown below (top freezer, too old) but listing one only way to get past screening
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
