Question about Dell Latitude CPX Notebook
Dell Latitude cpx
Screen flickers, then goes black, though the program is still running. I can swing the screen up and down, and it will come on again, briefly. Then it flickers and goes black again. Does this sound like a loose screen cable? Or an LCD converter? If so, how can I repair i?. Thanks. Great website.
    Genius:
  • 1,142 Answers
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
Posted on May 28, 2008
Latitude D630 screen is black from the time it is turned on. Computer is running, and I can see a little but it is mainly dark.
One of two components need to be replaced. The inverter board or the back light. The inverter is usually what will die. The inverter board is along the bottom of the display.
Mar 14, 2013 | Dell Latitude CPX Notebook
Dell lattitude cpx charging pin and - TERMINALS
What? Is it time to wake up?
Oh yeah, Dell Latitude CPX,
http://www.amazon.com/Dell-Latitude-Notebook-650-MHz-Pentium/dp/B00005UJYF
AC adapter example for above,
http://www.prontocharger.com/ProductDetails.asp?ProductCode=d1161
DC Power Jack example,
http://www.all-power-jack.com/Dell/Dell-Latitude-CPx.html
I see the dilemma. The plug from the AC adapter has 3 socket holes, and the DC Power Jack has 3 prongs.
DC electricity has a Positive connection, and a Negative connection.
To find out which socket holes are for Positive, and Negative, let's look again at the DC Power Jack,
The Top view shows the jack upside down, and turned around. (In relation to how it mounts on the motherboard )
The bottom left view shows the jack primarily how it sits, (Mounted), on the motherboard.
The bottom right view shows the jack turned over, laying on it's front.
Also laying over to it's right side.
Note the three prongs. (Flat bladed pins )
The one in the middle is Positive.
The two outer prongs are Negative.
Looking at the bottom Left view, the Top prong is Positive, and the two bottom prongs are Negative.
Match it up to the plug on the AC adapter cable.
Going to test the Voltage coming out? (20 Volts)
The red Positive probe lead goes into the top socket hole, in the plug.
The black Negative lead goes in either bottom socket hole.
What if I'm wrong?
A Digital multimeter will just show a negative value. -20
An Analog multimeter's needle will go down towards the 0, instead of towards 20 Volts. (DC)
Just switch the probe leads around.
For additional questions, or if I am way off base, post back in a Comment.
Regards,
joecoolvette
Apr 29, 2012 | Dell Computers & Internet
Will a Dell CPX sreen fit as a replacement on a Dell Latitude PP01L
hello ! I don't think so coz there made different and diferent connections .
And if not carefull u will end up burning that screen
S i suggest that u get a new cpx screen and fix it
good luck dude
Sep 08, 2009 | Dell Latitude C640 Notebook
Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Mar 15, 2009 | Dell Latitude D600 Notebook
Latitude cpx screen went black and turned off
No i doubt she has done that matey.
try fiddling with the charger cable there might be a loose connection, fiddle with it until the charge light comes on then you will know what your problem is :)
hope this helps
Feb 16, 2009 | Dell Latitude CPX Notebook
My Dell latitude Cpx laptop just does not power up, just flickers
I had the same problem on my CPx. It turned out to be a bad memory module. With bad (or no) RAM, nothing is going anywhere, so it immediately shuts down. New memory, no problems.
Jan 09, 2009 | Dell Latitude CPX Notebook
Dell latitude CPx not start properly
CHECK THE POWER...THAT IS UR SMPS CHECK IT WORK PROPERLY
Jan 11, 2008 | Dell Latitude CPX-J Notebook
Computer won't bootup
help have a dell latitude c800 must have a a email viruse cause it has blue screen with message "beginning dump on physical memory" then it has black screen with message disk error no drive found. did not get a cd for rebooting dont know what to do. it is refurbished and running windows 2000. would appreciate any and all help.
Nov 11, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Latitude CPX Notebook Logo
1,481 people viewed this question
Alun Cox
