Question about GE Spectra JBP78 Electric Kitchen Range
One range top control only goes to hi. Has no low setting
  • 30 Answers
Pudiera ser que el teclado se alla desgastado por uso normal o que se le allan derramado liquidos sobre el teclado
Posted on Oct 05, 2010
Cooking element on stove top goes on full heat,even when dial is set on low.
Electric, I presume. Disconnect power to stove, open backsplash, remove knob, replace control unit.(usually universal type). Available appliance repair shop. Careful with 220volt power!!!!
Sep 20, 2014 | Kitchen Ranges
The element goes from low to high unpredictably and must be turned off
replace the switch controlling that element. that should solve you problem.
Nov 26, 2011 | Roper FEP310 Electric Kitchen Range
I have a Beaumark Electric range about 8 years old, The right front burner comes on high as soon as it is turned on, even if I turn it to low it remains on very, very high and burns everything. Why
The burner is not controlled and so it is possible that there is no control on the heating coils.The thermostat settings must be checked as this can be an area where the coils are not controlled for the heat set but goes to the highest level.You will need to remove the unit to check the control action of the controller, check the thermostat and sensor.
Nov 22, 2011 | Kitchen Ranges
Brand new freezer set at 7 is creating excessive frost. Is it set too high or low maybe?
Hi and welcome to FixYa. I am Kelly. Each brand or temp control is silghtly different than even a like model on the display floor. However.... Most temp settings that are normal are right in the middle of the control setting range. Be it a mechanical control or an electronic control. If yours is a mechanical setting and the setting dial goes from 0 to 9 then the average temp setting would be between 4.25 and 5. A freezer should keep ice cream hard. If you do not have a thermometer then a small tub of ice cream makes a great thermometer. Each day i.e 24 hour period you reduce the setting 0.5 until you notice the ice cream is softening. Then once it softens increase the temp setting 0.75 of a between numbers setting. I.e The ice cream was soft at 3.5 then increase setting to 4.25 etc etc.
Thanks for chosing FixYa.
Kelly
P. S. If you need more detailed information please provide your freezer "make and model number" in you next response so we can provide you information applicable to your exact freezer.
Jul 27, 2010 | Refrigerators
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
Most smooth top elements only work on high
this is a voltage distribution issue
you would be better served to replace the
ERC
Electronic Range Control
Sep 29, 2009 | Kitchen Ranges
Coils on range get hotter when turning the knob to low
Monica,
You either have two bad surface unit switches or your knobs got switched around when cleaning.
Dec 18, 2008 | Kenmore Kitchen Ranges
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
GE Spectra JBP78 Electric Kitchen Range Logo
110 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
