Question about Magic Chef Refrigerators
Ihave amagic chef wine cooler mcwc16mcg I plug it in it runs for about 2 seconds and shuts off
  • Anonymous Mar 28, 2014
    come on and shuts off after about 2 mins
    Genius:
  • 1,122 Answers
YOUR COMPRESSOR IS SHORT CYCLING,YOU NEED TO BUY WHATS CALLED A 3 IN 1 STARTER KIT FROM LOCAL ALLPIANCE STORE,DIRECTIONS ARE RIGHT ON STARTER ,IT'S EASY TO DO,MAKE SURE YOU UNPLUG UNIT FIRST,THANKS-MIKE
Posted on May 28, 2008
  • MIKE major May 30, 2008
    WHT DID YOU GIVE ME A THANKS FOR TRYING ?DID IT NOT START YOUR COMPRESSOR? IF NOT THE COMPRESSOR IS WORN OUT,THANKS-MIKE
Whats the problem if the compressor on r-22 10 seer is hot and will not hold a charge when charging freon
Its time to replace unit, too costly to repair. In order to fix the unit it could run you more than replacing the unit. The leak needs to be fixed properly and can cost more the the replacement cost.
I hope this helps
Aug 15, 2011 | Magic Chef MCWC16MCG Wine Cooler
The compressor overload keeps poping when i plug the unit in.
I would suggest you plug it into a power bar with surge protector to see if that solves the problem.
Oct 13, 2010 | Magic Chef MCWC16MCG Wine Cooler
Hi, have a magic chef MCWC16MCG. I plugged it in to a a receptical and it wasn't working. Due to limited space I used an extension cord and a 3 prong adaptor (live and learn) so I could get it to a...
the extension cord must be # 12 wire size for better and the gorund should not be removed . ( proper polirty is important . ) do replace the start relay and if you have a ohm meter ck it for open or short to ground before installing the relay . ( good power is best ..or a short compressor life is for sure .. mm
Aug 11, 2010 | Magic Chef MCWC16MCG Wine Cooler
It makes a cleck after about 2minutes after it is
It sounds like the compressor is locked up. You can unplug the unit, then access the compressor and remove the electrical cover to access the start relay on the compressor. Carefully remove, disconnect wires, and purchase a new one. Replace in reverse order of dis-assembly, and hope the compressor will start again. If not, time to buy a new wine cooler as the cost of repair will probably exceed the cost of a new cooler, unless you are within the 5 year warranty period for the compressor, and even then it will cost for labor and other consumables used to replace the compressor.
Dec 14, 2009 | Magic Chef MCWC16MCG Wine Cooler
I have a magic chef wine cooler model mcwc16mcg justs keeping clicking not cold anymore , can this be fixed
A clicking sound every few minutes usually means the compressor is going off on overload when trying to start. This could mean the start parts are bad, or the compressor went bad.
Nov 22, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
NOTHING HAVPPES WHENI PLUG IT IN AND TURN SWITCH
Hello Sir,
Make sure that the fuse or the relay of the supply unit is intact and in working condition. If not that there is some trouble in the power supply unit.
Regards.
Nov 15, 2009 | Magic Chef MCWC16MCG Wine Cooler
Light flashes on and off, and fridge does not work
Lamp loose connection?
Try using a different bulb ?
Sep 07, 2009 | Magic Chef MCWC16MCG Wine Cooler
MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Jun 29, 2009 | Magic Chef MCWC16MCG Wine Cooler
Refrigerators Logo
121 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
