Question about Samsung LA46M81BDX 46 in. LCD TV
ON/OFF SWITCH DOES NOT WORK - REMOTE CONTROL WILL NOT TURN IT ON EITHER
    Problem Solver:
  • 17 Answers
Just replace ur power switch
Posted on Oct 05, 2010
  • tjwpjw Oct 05, 2010
    I HAVE BEEN TOLD IT IS THE CAPACITORS AND THEY NEED TO BE REPLACED AND SOLDERED.
I have an emish tv box the remote switches it off and on if I press it after about 5 seconds. But if I switch it off with the remote i have to use switch on back of box to switch back on
DIRECTV - Support: Your Remote Control
www.directv.com/DTVAPP/equipment/demoInfo.jsp?assetId...
DIRECTVTrying to get your DIRECTV remote control to work with other devices? ... TV Power On & Off - If your receiver turns off while the TV turns on, press TV Power On ...
Program the remote for your TV - Fiber Help
support.google.com > ... > About the remote control
GoogleThe Google Fiber remote control is not designed to fully control external audio equipment. ... Press and hold the button on the original TV remote that you want to program on the Google Fiber remote. If the learning works, the TV power button on the Google Fiber remote blinks twice ...
Dec 26, 2015 | Televison & Video
I don't know what model my fan is, but it's only 3 years old and suddenly two days ago the light and fan quit working. We replaced the light switch on the wall-nothing. Took apart whatwe could of the fan...
That may be, because you were using the Remote Control to operate it, but then turned off the wall switch instead of turning it off using the Remote Control.
Turn the wall switch back On and try to get the Remote Control to take back over the operation. If that solves your problem, in the future you will know to turn off the fan and lights with the remote, before turning off the wall switch.
Hope this helps solve your problem. My wife had to learn the same way with ours.
Feb 04, 2011 | Hampton Bay Heating & Cooling
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Can't control light at switch
It is wired so that you control the light with the remote. You cannot have it both ways. You either control it with the wall switch or the remote. Once you kill the power to the receiver by turning off power at the wall switch, you are only applying power to the receiver when you turn power back on. You are not supplying power to the light. You then must turn on the light with the remote. This is the purpose of a remote fan/light control. You could rewire it to control the light with the switch and only control the fan with the remote if you wish, but as you have it now, it is working correctly.
Jul 01, 2009 | Hunter 27185 Remote Control
Hunter Fan - Remote
Most likely the fan turns on with a wall switch and then as long as the power is there [ wall switch left in on position], the remote works
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Dec 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Ceiling fan
If the switch is "OFF" on the wall, the remote will not control anything. The power has to reach the receiver first. If it worked before you turrned the swich off, than one of two things. Either
A: You blew a circuit to the unit or
B: Your receiver went out.
First thing I would do is check that POWER is getting to the receiver.
Sep 06, 2008 | Universal Remote Control Hampton Bay...
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Samsung LA46M81BDX 46 in. LCD TV Logo
65 people viewed this question
Jerry Greenberg
Jerry Greenberg
