Question about Microwave Ovens
My brandt built in microwave is showing message dEno-what is problem?
  • coutts_jenny Oct 05, 2010
    Thanks-it is reading "deno" I mentioned the model number-it is ME645M and despite hours of searching I cannot find a manual on the internet.
    I suspect that the heat from the self cleaning mode on built in oven which is located directly below may have caused the problem.It is not working at all and is only one and a half years old.
    jenny
  • Microwave Ovens Master
  • 17,129 Answers
First of all it is reading DEMO and not working? If so it is possible that the controller unit is displaying the program settings but has errors on the main program controller unit. You can try and see after opening the cover to trace the fault. Atttempt only if you are competent to do so and with proper tools.
If there is no action please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - fuse .step down supply( trans former or SMPS), the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Since your model was not specified a general fault finding tip was provided, but please respond after checking this out..
Posted on Oct 05, 2010
  • Donald DCruz
    Donald DCruz Oct 05, 2010
    Thanks for clarifying , I will try and get back after veryfing the model manual.
Error message econ
I appreciate your post, friend!
Based off the information you have provided your Electrolux built in microwave is displaying an error code of "ECON". I am showing that this is an invalid error code. I would recommend you perform a reset on your microwave and you can do that by disconnecting the power cord for roughly ten minutes. If that does not help correct your issue I would suggest contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Mar 16, 2015 | Electrolux EW30MO55HS Built In Microwave
Whirlpool f1e5 fault detected, disable power to clear
just go to breaker box and turn off the breaker that powers the stove
Jun 06, 2014 | Whirlpool RMC275PV Built-in Microwave...
I have a Brandt induction cooktop and 2 hotplates don't work at all and the other 2 now don't appear to be connecting with the saucepan. Heat light starts to flash then turns off completely. Unable to...
Sounds like a wiring problem,take off of course with no power and check it out. No harm if no power,and replace wire and or componet with same.
Jan 11, 2011 | Brandt Microwave Ovens
Have a brandt 4 burner induction cooktop about 8 years old. 2 left hand burners no longer operate. is this a common problem? can it be repaired?
Replace the burner and the control where ever necessary ... this is not uncommon and easily repaired.
Jul 21, 2010 | Microwave Ovens
Error message E8 is shown in the clock display
Error Code: E8 Cause: Control Board Example: Remains in display; oven unusable Corrective Action: Replace control board
Apr 12, 2010 | Bosch HMT8625GB Microwave Oven
How to set clock
Try these combinations:
Clock > 1 > 2 > 3 > Clock
Clock > 1 > 2 > 3 > Start
Clear > Clock > 1 > 2 > 3 > Clock
Clear > Clock > 1 > 2 > 3 > Start
If that doesn't work, contact the dealer you got it from and ask them for contact information for Brandt.
Oct 09, 2009 | Brandt S2600WF1 / S2600BF1 / S2600TF1 1550...
MICROWAVE D9023EFL BRANDT MODEL
Brandt is overhauling their Web site, so i would call 0870 240 8095 for parts.
If you are not in the UK, please let me know.
Aug 09, 2008 | Brandt Microwave Ovens
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
