Question about Frigidaire Kitchen Ranges
Locked open oven door
Oven door open and locked. What do I do? Cannot get it to unlock. Help!
  • trible May 28, 2008
    It wasn't forced open but accidently pushed clean pad and immediatly opened. It then locked itself. Pushing the clear button does not unlock the door.
  • 13,433 Answers
Can you tell us more about your product?
Posted on Jun 01, 2008
    President:
  • 2,712 Answers
Can you please provide more details including the model number, etc..
Posted on May 28, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE
    EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL
    THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE
    THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF
    THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP
    IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
    THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR
    SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND
    REPLACE IT WITH THE ONE PLUGGED IN.
  • Swilin Sampson
    Or try these:
    1. Unplug the oven from the AC source, and turn off the circuit breaker. Wait about 5 minutes and turn on the breaker and plug in the oven.
    2. Open door with the oven on, push in on the door switch and hold it. Hit clean while
    holding the switch and count to ten and release the swith. Turn the circuit breaker off for about 20 seconds and turn it on again.
    3. Otherwise, with the breaker on, tap the door latch with a hammer (lightly!) to the left. Hopefully, it should slowly move to the left and resolve the issue.
  • Swilin Sampson
    Try this link as well:
    http://www.appliance411.com/links/jump.c...
    Please "Accept" my solution, if it leads you to a Fix. Thnaks.
    Brigadier General:
  • 3,614 Answers
Kindly first check the interlock switch, and for some broken fuse on the unit..
Thank you
  • micromaster
    micromaster May 28, 2008
    if my info/idea helps you, please kindly rate my solution.
Why is oven door locked and won't open?
Troubleshooting a GE Oven That Can Not Get Out of Locked ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
Oven door is locked and won't open
oven door locked during cleaning then would not unlock after cooling
Jan 19, 2010 | GE JKP86 Electric Double Oven
Kenmore oven 41775790 locked door
after self cleaning with the racks still in oven, i cannot get the oven door open, locked down, does this have something to do with the racks left in oven during cleaning. what do i need to do
Jan 17, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Dec 22, 2008 | Jenn-Air Electric Double Oven
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Door locked
resetting thebreaker sometimes will work. if not try setting to clean. after engages the door to clean simply cancel the cycle the door lock/latch will cycleback . perhaps it just glitched shut.
Mar 12, 2008 | Frigidaire FEB27S5A Electric Single Oven
"Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Jan 20, 2008 | GE Profile JTP18 Electric Single Oven
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
82 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
