Question about Samsung CLP-600N Laser Printer
Whare can I get the SMPS for CLP600?
Suddenly my CLP600 power down and never power up. I pulled out SMPS and Check the voltage at each connector but no power read by multimeter.
I checked all components if there were burning mark by vidual but no burning mark. Is there any one who has same experience and please let me know where can I buy that SMPS?
PCB board says PSP-TYPE5-SUB-V1 SUB REV 1,3
Thanks
  • beh1 Jun 05, 2008
    I had the same problem. Turned out to be the fuse on the SMPS board. At first, I ignored it because it looked fine. Then after messing around with it for a while, I actually pulled the fuse & tested the resistance across it-then I KNEW it was bad. Put a new one in and presto, printing again. Double check that little fuse-might be a nice surprise!
Http://www.mk-elektronic.de/Hersteller/PDFDokumente/Samsung/Color-Drucker/CLP-600.pdf
I had the same issue. Samsung replaced two boards and the printer works again. The board that has the fuse is on page 2, box 11 (I think fuse is #10 in that box). I can't figure out where the 2nd replaced board is on this chart.
I did not test the fuse, so I can't say if it was the problem or not.
Hope this helps.
Posted on Dec 17, 2008
Can anyone tell me where the SMPS board and fuse are. I need a diagram to check the board or fuse. Is it is the front of the machine or what?  gharris@msrce.howard.edu
Posted on Jun 20, 2008
Power supply output voltage
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 11, 2015 | LG Televison & Video
How many fuses on smps power supply?
BN power supply schematics are given.
Mar 10, 2015 | Televison & Video
Smps output voltage is gradually increasing
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Replace all the zener diode used with new ones.
Aug 06, 2014 | Sanyo Televison & Video
Trembling and vertical overlay image : how to fix it ?
Main power supply regulator board fault. DC voltage output from it is abnormal. Contact any service technician.
It will be best to replace the power supply regulator board as card basis.
Jul 30, 2014 | Samsung UA-32D4000 MULTI SYSTEM LED TV...
Tv suddenly trned off and blinking red,why?
switch off the tv & try to turn on after 10 min. if it happens again there may be loose connectors inside tv. if you can do: unplug the tv remove the back cover & have a close look for loose connectors.
Aug 19, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
50 in lg plasma wont turn on just clicks
hi,
you have to check the power supply first.
As u mentioned about the click sound, the 5v standby supply is ok. The click sound you hear is from the standby relay.
you have to check the other power supplies in the SMPS (switch mode power supply board) board.
first of all check the standby supply 5v on tne pin of connector P800. check the voltage at this point in standby condition and at the time of power on. it should stay at 5v. if it reduces the you have to check the components related with standby SMPS transformer T501.
If the 5v volt is ok the u have to check the 3.4 v at the pin 1 and 2 of connector P802, at the time of power on. if it is missing then check the components related to T112 ,also check the following voltages at the same power on condition.
19v at Pin 1and 2 of P803
6v at the pin 5 and 6 of P802
12v at the pin 9and 10 of P802
check these to verify your tv's power supply
proper care should be taken while working with power supply, because there is risk of getting electric shock.
if you need any more assistance fell free to contact me through fixya.
I have with me its field service manual ( does not have any schematics) if u need that i will sent it to you, if u give me your email id through fixya.
ok
Jan 18, 2011 | LG 50PC3D 50 in. Plasma Television
Checked all but not helpful. when i disconnect high voltage connectors from supply unit then power led goes stable but no display
This is typical as the SMPS power supply is shorted when the connector is on to the board. when you remove the connector, the short releases and the power resumes as the SMPS has a high current cut off for protection.
So the easy way out is to have a multimeter and check the power line to the circuit disconnected to check out the shorted driver. Once you have zeroed in to the component release and connect power supply to confirm. Now replace the shorted component.
make sure that any high voltage in circuits are discharged when you use the ohmmeter in the circuit.
Oct 11, 2010 | Philips Computers & Internet
Computer won't power up
Make off power.
Remove the RAM.
Check the beepcode occurs or not.
If beepcode is long then RAM DEFECTIVE.
===> Erase to polish contacts of RAM with soft white presto eraser.
If beepcode not sound, open Processor and recheck. same.
If again negative, just short green and black wire of SMPS after opening from motherboard. SMPS must start and check all voltages. If not start SMPS Defective.
Please give your feedback so that further repaire can be made.
Thanks
Jan 24, 2010 | Ultra (ULT31554) 500-Watt Power Supply
Computer suddenly dies intermittently
Hi..
In this case when it is always beeping during the computer is on. You need to check the memory stick if it is not faulty. Remove the memory stick and clean it from dust. Clean also the memory slot and reinsert the memory stick. If the problem still occur try to use the other memory slot.
Regards
PCmania
Aug 28, 2009 | Packard Bell (181368) Motherboard
Trunk pull Down Motor Suddenly stopped working
did it quit making the noise when you lightly push down on the trunk? most people slam these trunks and your not suppose to you are only to put light pressure on them and they pull it closed theirself.. you might check your relays under the hood and look in the box lid to see which one it is.. if this is not the problem you might have to replace the motor to the latch .. you might check with a test light to see if there is power to the motor first though .. thanks and holler if you have more Jerry .
Apr 23, 2009 | 2004 Lincoln Town Car
Samsung CLP-600N Laser Printer Logo
405 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
