Question about JVC Everio GZ-MG21 Camcorder
Flex crack - JVC Everio GZ-MG21 Camcorder
    Genius:
  • 1,812 Answers
The flexible ribbon cable that connects the LCD to the camera body can be replaced fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 10, 2010
Broken slight crack front Glass , where to repair.
that slight crack is a lousy thing because its cracked where the flex ribbon that connects to the digitizer is located , and it means that the flex ribbon was damaged also and its garbage, the digitizer and lcd
sorry
May 08, 2016 | Cell Phones
Knocking noise after replacing automatic transmission in 98 ford escort zx2 4cylinder
Three most likely causes are: #1 You forgot to tighten up all the torque converter to flex plate nuts/bolts. #2 You cracked the flex plate during the transmission change. #3 You forgot to swap one or both of the alignment dowels from the old transmission to the new one during the change. These are hollow dowel pins. They go between the bell housing of the transmission and the engine block. Failure to have both dowels in place will lead to the flex plate cracking [see #2]
Mar 10, 2015 | 1998 Ford Escort
Cracked flex cable so pls help
REPLACE CABLE OR PAINT WITH LIQUID WIRE INSULATION.
Oct 31, 2014 | Cameras
My 2007 grand cherokee limited 3.0lt turbo diesel has a serious rattle in the transmission, would this be a cracked flex plate?
Other possibilities can be bad trans mount, heat shied on cat or bad catalyst conv. Or engine mount leaning on frame
Dec 11, 2013 | Jeep Cars & Trucks
Clicking or rattle underneath my 99 silverado
That sounds like its your flex plate has cracked.Take the flex plate inspection cover off and look for cracks up towards the center of crankshaft.I'm pretty sure you will find it to have cracks coming from the center outwards.
Oct 17, 2012 | 1999 Chevrolet Silverado 1500
My 85 monte carlo ss is making a clicking sound. It seems like the sound is coming from under the car near the tranny. I don't know what it is. All my fluids are ok. Please help
Noises are very hard to diagnose without actually hearing it. If it sounds like it is coming from around the tranny you may have a cracked flex plate. The flex plate is bolted onto the end of the crankshaft and is between the engine and transmission. It connects the crankshaft to the torque converter of the transmission. It also has a gear around it that the starter uses to turn the engine over. Have you noticed the starter sounding different when you start your car. A cracked flex plate will cause that or you may have a faulty starter causing your sound. Flex plates get cracks around the bolts that hold it to the crankshaft and can make a clicking noise. You may be able to remove the cover off of the bottom of the bell housing of the transmission and inspect it. Look for cracks or rust trails which is evidence of a crack. Not sure if you will be able to see far enough up in there or not. Rotate the engine around a little so you can get a look all of the way around it. It could be an engine or valve train noise also. Noises can ressonate through other components and make it hard to pinpoint. You may need to get some kind of stethoscope to help locate it.
Apr 30, 2011 | Chevrolet Monte Carlo Cars & Trucks
Cracked flex plate. 2002 Elantre w/auto trans???
you can try to buy new fly wheel or flex wheel at a auto parts stores but more likely dealership part.reason for flex plate to cracked due to stress and heat or starter bolt breaks causing starter hit flex wheel.
Apr 15, 2011 | Hyundai Motor 2002 Elantra
NOISY FLEX PLATE, KEEPS CRACKING AROUND MOUNT ING SCREWS (3) , WELDED UP CRACKS AND REPLACE SCREWS, IN A WEEK STARTS GETTING NOISY AGAIN WE HAVE WELDED THESES CRACKS 3 TIME NOW, HAVE REPLACED NEW FLEX...
sounds like it is incorrect flex plate
for bolts to keep coming loose i wouldsay the bolt threads in end of crank have been streched thru over tightening
you may be able to redrill and tap these
to do this you will have to pull engine
you alsocannot weld craCKS IN A FLEX PLATE
FLEX PLATES flex THEREFORE WELDING IS A WASTE OF TIME
WELDING WILL ALSO PUT FLEX PLATE OUT OF BALANCE WHICH AGIAN WILL CAUSE CRACKS AND PROBABLY WAS THE ORIGINAL PROBLEM TO START WITH
Dec 14, 2010 | 1991 Eagle Summit
My phone was dropped and now I can't see anything on the screen.
If the screen of your phone is not crack, the problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying. But if the screen is crack, you will need to get a brand new screen to solve the problem.
Take care.
Jul 28, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
I have a Hayward sand filter and the top is cracked and leaks. When I patch it, it just cracks somewhere else
those tanks are designed to hold alot of pressure. If it is cracked, it's already unsafe. When the pump turns on, the tanks usually flex a little bit, depending on your system. The flexing usually makes the patch come undone. It's best, and safer, to replace the filter tank.
Apr 05, 2010 | Hayward SAND FILTER, PRO SERIES
JVC Everio GZ-MG21 Camcorder Logo
145 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
