Question about RCA P52926 52" Rear Projection Television
Turn on when you plug it in power surges,but does not power up
  • 927 Answers
It sounds like you may a short in one Tv's circuits. I would call an authorized service center. There is no easy way out of this one!
Posted on Jun 01, 2008
Canon pixma mg5220 will not turn on
When you have sparks it toasts the chips even a good teck will ground themselves before opening a peice of equipment like that. I'm sorry to say but I doubt very seriously if either piece of equipment will work. I would also get rid of the surge protecter and have that outlet looked at.
Oct 14, 2015 | Canon PIXMA Office Equipment & Supplies
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
Cannot get power to our canon mp830
plug in a light into surge protector and see if it works if not surge protector is bad or battery is shot if it has one!!i have numerous surge protectors that went bad try plugging printer into wall outlet and if working its surge protector!!!
Jun 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ihave a sony KP53S75 TV there was apower surge and now there is no picture. The red light blinks 4 times can anyone tell me about this?
Hi, if this TV was hit by the surge and it was protected by a surge protector, please follow this reset procedure.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the problem is still there and the light is still blinking 4 times, this means that the surge has destroyed the Vertical deflection component. in this case, it will have to be replaced.
please rate and have a great day.
Mar 25, 2009 | Sony KP-53S75 53" Rear Projection...
Last night I turned-off my PC througg Windows and when I pushed the power button this morning nothing hapened. There is no sign of "life" from the PC.
Check the power source to the computer (both ends of the cord), if a surge protector is in line with the power , remove it and plug the computer straight into the wall. also check the wall plug with a lamp or something to ensure power there. make sure the switch on the power supply hasnt been changed to the 220v side.
If no power at the wall- check your breaker box in the house
If it works plugged straight into the wall- check the surge protector
If power at the wall and plugged straight into the computer (no surge protector) and nothing lights up when you turn it on- have your power supply checked.
Oct 08, 2008 | Acer Computers & Internet
Computer power won't turn on
First thing to do is try to plug the pc in another wall socket to see if it goes on, If not, the MB could have gotten fried, even though the other plugs seem to work. Hopfully you just need another surge protector as that could have gotten damaged.
Jul 20, 2008 | Computers & Internet
Comp won't power on
Hi KlubeT,
I would suggest replacing the PSU (Power Supply Unit).
Jan 31, 2008 | Dell OptiPlex GX270 PC Desktop
Out of Range
Do you have power to the base? I've seen this message on several cordless phones if the base is unplugged, the power brick has failed or the power adapter was plugged into a power strip (or surge protector) that has been turned off. It can also happen if the circuit breaker for that outlet has tripped.
First check that the power adapter is plugged into an outlet and the other end is plugged into the base. If the power brick is cold, check that the outlet has power by plugging in a different device (like a lamp) and turning that device on. If there is power, than you need to replace the power adapter or the entire phone (if you can't match the amperage output of the adapter). If there is no power at the outlet and the adapter is plugged directly into the wall outlet, check your circuit breaker for that outlet.
If you used a power strip or surge protector, check if it is on. For a surge protector, check if the surge protection circuit light is on. Replace bad surge protector.
I hope this helps.
(I have seen someone intentionally turn off a surge protector during an extended power outage and then fail to turn it back on after power returned. The individual forgot that they had turned things off before they called for assistance with their phone.)
Aug 17, 2017 | GE -25893GE3 Cordless Phone
Receiver won't power on
My receiver was turned on and plugged into a surge protector along with my LCD TV. The power went out and everything shut down.
Dec 28, 2006 | Pioneer VSX-D514 Receiver
RCA P52926 52" Rear Projection Television Logo
24 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
