Question about Technics Audio Players & Recorders
Technics Amplifier SU-VZ320 plays sound for a while and just cuts out sound. Tried switching off and on but no sounds comes through. Leave it off for a while then turn it back on get sound then cuts out again!
  • 30 Answers
Puede ser un problema con la fuente de poder de la planta,con los parlantes,con los cables y terminales que conectan los parlantes con la planta ,puesto que la mayoria de amplificadores tienen control de temperatura y al sobrecalentarce se apaga por protecion y por eso ensiende por un rato y despues se apaga, por favor revice que los parlantes y los cables con teminales esten bien y no esten aciendo contacto
Posted on Oct 05, 2010
Service manual Su-VZ320
send your email so i can help you
Jan 30, 2014 | Technics Audio Players & Recorders
I have a technics hifi su-ch900 everytime I play a cd or cassette or have the tuner the sound cuts out when its slightly loud, on low volume its fine. I have checked the cables and they are correctly...
I found a link to a CH900 that switched off completely.
If you are not a technician, please don't open the amplifier.
But I think it will be a simple repair. It is not the same problem, but it looks a little simelar.
http://www.electronicspoint.com/technics-su-ch900-switching-off-t53309.html
Also found a service manual, but not complete. Still here is the link
http://elektrotanya.com/technics_su-ch900.pdf/download.html
Oct 30, 2013 | Audio Players & Recorders
Technics Amplifier SU-V4
The clicking sound will be a relay for the protection circuit. That could be faulty, but first check out the main devices on the main amp section. Those attached to the big heat sink. If you see a single IC amp that could well be faulty.
Oct 04, 2013 | Audio Players & Recorders
I have a technics SU-V98-KM8 Amplifier that turns on and lights up but does not have any soundd coming out of it. I have checked alll the cables and cords and everything is hooked up the way its supposed...
Your amplifier is turned on and all the indicator lights work and you made it sure that all the cables, and cords are attached to where they are supposed to be connected and yet you don't get any sound coming out when you play a music. Amplifiers have selector knobs for you to set where your source is coming from. Selector knobs can be set to TUNER, DVD, CD, and AUX. The scenario might be like this: your source is coming from a movie being played on your DVD player connected to your amplifier but your knob selector is set to AUX. Try playing a music selection from your CD player attached to your amplifier and set the selector knob to CD. If still there is no sound coming out you need to have it checked by a qualified technician.
Jul 23, 2011 | Technics Audio Players & Recorders
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Technics amplifier su-v98, cuts off at 22-24 desibls
The most common cause of this is defective coupling caps inside. These allow some DC voltage to pass through to the final amp stage. This DDC voltage is detected by the protection circuit and the unit shuts down. This unit will require service. Please note that this should be a simple and inexpensive repair. The cost should be less than $10 for parts.
Dan
Jul 04, 2009 | Technics SUV500 2-Channel Amplifier
Technics su z2 amp shuts off sound
hello. we cant help if we dont know what music source you are using.
Apr 13, 2009 | Technics SA-AX530 Receiver
Sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Mar 14, 2008 | Technics SUV500 2-Channel Amplifier
718 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
