Question about Canon IXUS 80 IS Digital Camera
Camera won't turn on, battery is charge but no power. We have second back up battery which we tryed but still doesn't work. so not a battery problem. Is there a reset button?
I am facing the same problem for my camera. Please let me know if anyone knows of a solution.
Posted on Oct 23, 2010
4 Suggested Answers
SOURCE: Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Posted on Aug 06, 2009
SOURCE: I hit the power button and it turns green for a
Hi i have struggled with this within few months of buying the camera.
Both the charger and camera are not making a good connection with the battery. i clean with alcohol, this usually helps with the charger. When powering up in camera it helps to hold the battery in further and just keep hitting the power button. It always works eventually.
In the meantime my display has lost backlighting. i will never buy another Sony camera.
good luck, Karl
Posted on May 20, 2010
darntoothysa
  • 489 Answers
SOURCE: I have a powershot G11. I charged my battery and
The G9 has a design defect with screws that loosen, fall out, and short out the camera. I don't think the G11 has this problem, but it is most likely the fuse on the DC/DC board that has 'blown' causing there to be no power.
I'm not sure how much the part costs, usually about $30-40. We repair the no power problem for the Canon G9 for $85 incl parts, installation and return shipping of the camera.
Thomas Drayton
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Posted on Sep 07, 2011
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
My camera wil not power on.
Depending on the situation, it could be several issues.
- Battery may not be charged, or wasn't charged properly. - Battery is cold. - Camera may actually still be on, but it won't show on the monitor because you may have them turned off.
Try this: Press DISP until shooting data or photo information displays, it should show up at some point. If it doesn't then it has to be the battery.
If you don't think it is, try and provide extra information on when was the last time you used it or the last time you charged the battery and etc. Thanks!
Aug 23, 2011 | Nikon COOLPIX P80 Digital Camera
My camera won't turn on i charged it and now it won't turn on!
This truly depends on the make and model of your camera. If it uses a rechargeable pack, make sure to fully charge the battery and try it. If this still doesn't work, try plugging it in the computer via USB. If it turns on, then your battery pack may be causing the problem. I would suggest you to bring it to your nearest service center for them to check it out, especially if you still have warranty and so they can replace the battery pack. Some cameras have a reset button at the very bottom (or look into your camera's manual if there is such a thing for your camera) which could be an option as well.
Jun 14, 2011 | Cameras
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Camera comes on for 2 seconds and shuts off. battery charged and good condition
Here are the steps for no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 20, 2010 | Kodak EasyShare M863 Digital Camera
I have Kodak EasyShere V1223 It won,t Turn on, Go
Here are the steps for V1223 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 17, 2010 | Kodak EasyShare One Digital Camera
Power key doesn´t work
There must be a problem with your batteries. If you have recently charged your batteries and it happens again, you should try a new set of rechargeable batteries.
You can try conserving charging power usage on camera by turning the flash off so that it doesn't precharge for the next shot.
Jun 04, 2008 | Samsung Digimax i6 PMP Digital Camera
Canon IXUS 80 IS Digital Camera Logo
229 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
