Question about GE Washing Machines
I have a GE WJRE5550K2WW top load washer that we recently bought. This last weekend my daughter ran an experiment for a science class where she ran the wash cycle several times without letting the rest of the cycle finish. Since then the washer makes a lot of noise when it is agitating. When I lift the lid it appears that it is agitating very aggressively. I am assuming that the controller got confused by the weird cycles that were run. Is there anyway to reset the washing machine so that it will return to normal operation?
Brent, I know this was posted over a year ago... I'm assuming you found the answer by now; but for the benefit of others, here's what I found out as I have the same model of washer... to reset, unplug the washer and wait at least 1 minute before you plug back to the wall outlet. Then open the lid 6 times.
Posted on Jun 10, 2013
  • 30 Answers
Yo creo que no puede ser el control puesto que no guarda memoria de los siclos me parece mas bien que pudo ser que se desmonto o se desgasto alguna piesa interna del mecanismo de la lavadora por el uso execivo al que fue expuesta para el experimento
Posted on Oct 05, 2010
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
I need to adjust water level GE wjre5550k2ww, I need more water. I have well water so I not concerned about using a little more water.
you may need to check your pressure switch. if you have a mulitmeter use it to find any electrical issues. if you have no reading the switch needs to be replaced
Jan 31, 2011 | GE WHSB8000B Top Load Washer
GE washer model WJRE5550K2WW - will fill water and drain but does not agitate and spin.
It new to me I am working on a GE washer model wjre5550k2ww it fill but not washing I can put it into the spin and it release the water but do not spin
Jan 05, 2011 | Washing Machines
How do i remove the front to check or replace belt
If you need an owner's manual see this site.
http://genet.geappliances.com/DocSearch/Dispatcher
Unless GE has changed in recent years the motor and transmission can be serviced from the rear of the washer. GE engineering did not have a front service panel when I serviced them. Belts usually last a long time, look for a bound water pump or other problems.
Jul 10, 2010 | GE WBSE2090A Top Load Washer
Touch Screen on GE profile top load washer is not responding.
There is probably a problem with one of the following:
* electronic control board
* touchpad
Feb 24, 2010 | GE Profile WPRE6100G Top Load Washer
Loud knocking sound when in wash cycle GEWDSR2080
After taking off the front cover, look up at the top of the tub just under the lid. there should be a thick rubber strap at each corner of the machine tying in the tub to the top. These are called dampening straps. One or more may be broken. I usually replace all four if I do one.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
No Washing ...
cold water screen on the washer is plugged or the pressure switch is bad
Nov 28, 2006 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
696 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
