Question about Garden
I need new spring for rope start on bahramshahr chain saw where cani get it ?
  • 4,340 Answers
Try a lawnmower shop, but this item needs to come from the manufacturer.
Posted on Oct 05, 2010
Recoil spring problem
I have the same chainsaw and have never had a problem with it.
If you have changed the starter rope or recoil spring in the past, it is important that you hold the new spring with needle nose pliers and install it correctly. Once the spring is in make sure wind the rope correctly-clockwise. If not the new spring will be damaged.
Sep 14, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
Installing a spring in an MS240 Stihl chain saw
I have not worked on you type saw. I have put new starter springs in other saws. One end of the spring fits into the housing and the other in the pulley. Once you have that done there should be a notch in the pulley that you put the rope into that will allow the spring to be wound up without taking up the rope. It is a trial error problem now. If the spring is wound too tight you will not get full rope travel. If it is too loose tilt will not pull the rope in fully.
Jun 01, 2013 | nwp Starter Recoil Spring Fits Stihl 024...
How does the recoil spring,waher,2 hairpins pins,dog footand rope pulley get reassembeled?
the rope rotor will go on first, then the washer goes on, put the dogs in then put the spring on. insert the rope into the rotor, wind it up, feed the rope through the starter cover, carefully allow the rotor to wind in the rope a ways then put the handle on.
Dec 20, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
Starter rope will not pull out all the way. What could the problem be?
There are two possible reasons, one is the rope is too short, or two the starter spring is wound too tight, and is coil binding, start by fitted a new starter cord, and re tention the spring, so as you still can turn the pulley by hand at least a further 1/2 turn with the cord fully out ( to avoid coil binding the spring )
Feb 06, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Rope broke when i try to start it
Take the chain saw apart. You will see a small canister where the rope is located. It is spring loaded remove the rope install a new one and rewind the chain. Hope this helps.
Aug 20, 2009 | Garden
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pull start on my wild thing keeps jamming
you can not pull the starter rope out to full length. Just short rapid jerks. everyone has this problem
Jan 26, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pull cord on chain saw will not retract.
Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
Jan 02, 2009 | Husqvarna Chain Saw 20" Bar
Broken Pull String
Yes, it is possible that the spring needs to be pre-tensioned. its also possible that something was put together a little out of alignment, or some part is too tight and its too hard for the spring to wind in the chord. try to reassemble the chainsaw with a couple more turns on the spring and see if that helps.
paul
Oct 30, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
156 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
