CT-32SC14J Panasonic My TV won't turn on. It was working fine few hours ago and I turned it off with the remote control. Now it won't turn on. It does not have a reset button in the back.
  • txunik73 Feb 26, 2009
    where do i locate the fuse in the panasonic
    ct-32sc14j
  • 71 Answers
Unit has a fuse inside. be sure to unplug set from ac before opening
Posted on May 28, 2008
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
My panasonic tv is turn off what should i do because my remote control is broken
Yes. You can. Buy one universal remote control which has setup codes for Panasonic TV. You can get this detail from the code list attached to universal remote pack. Universal remote control codes for Panasonic TV are:
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Jul 07, 2012 | Panasonic CT-36D32 36" TV
I cut the tv off with a universal remote and now it won't come back on??
Its a 32 Inch Panasonic ( indicated here) a lot of these were Famous for the 6.3 amp glass line fuse inside blowing for no reason.
Make sure if the fuse is bad get a good one and not a generic from Radio Shack--------Let me know if you have questions.
Mar 15, 2012 | Panasonic CT-32HXC14 32" TV
Won''t turn on the tv also cannot change the settings manually on the tv
Thanks for stopping by.
What is the model number and manufacturer of the TV you are trying to control with the CT-90157 remote?
Not all IR codes are programmed into all remotes.
Sep 26, 2011 | Toshiba CT-90157 Remote Control
Panasonic 32" GAOO just atarted doing this...Turn
The Panasonic Gaoo sets were top of the line in it's day, the problem you are describing is a vertical deflection issue caused by bad solder joints and a few parts. I recommend a tv technician to fix the set.
Jan 09, 2011 | Panasonic CT-34WX50 34" TV
I have a problem with my Panasonic CT-27SX12 27"
On remote you must push the TV button first then the on button to activate or deactivate the TV. Channel or volume on the TV does not need to select anything on remotes.
Nov 18, 2010 | Panasonic CT-27SX12 27" TV
My Panasonic HDTV will not turn on
Mine did the same thing. Did you find out what to do?
Oct 11, 2009 | Panasonic CT-26WX15 26" TV
Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Panasonic CT-32SL14 flat screen tv stopped working
We played Wii sports and fit for few hours than tv started to flicker and change colors to green and black and white. We shut down Wii and not TV screen doesn't show any picture. The power is there and the sound... but the screen is just blue. Any one experienced anything similar?
May 20, 2008 | Panasonic CT-32SL14 32" TV
Televison & Video Logo
367 people viewed this question
Top Televison & Video Experts
