Question about OKI Office Equipment & Supplies
My scanner is OKI mb 290.when i press the scan button it trys to scan then displays message "operatio unsuccessiful."
  • 244 Answers
SOURCE: ERROR MESSAGE KEEPS APPEARING!
Please reinstall the driver as well uninstall it first before reinstall the driver.
Please rate me Solved if you like my answer.
Best regards,
Philip
Posted on Nov 05, 2007
SOURCE: sir, i have a microtek
I need your helping.Thanks.
Posted on Mar 19, 2009
  • 108 Answers
SOURCE: There is no application registered for this event
In the software setup, there will be a place where you program each of the Application Buttons to access a program you have installed on your computer.
Examples are: Photoshop, Email, OCR, Corel Photopaint, etc. any program that could use a feature called, "Aquire" which is simply getting a graphic from the scanner.
Be shure to install the Applications disc that came with the scanner, (not just the driver). And run the configuration, or settings tool, to set up what programs will run when you press the Quick access buttons on the scanner.
Otherwise, you can access the scanner features from a menu item called "Aquire" in Photoshop, Corel photopaint, or in Microsoft Office it's in the menu, string Insert - Image - from scanner or camera.
There are some complications with the WIA driver, and reccomends using the ScanGear CS software instead. I'm guessing WIA is (Windows Interface Access, or Windows Instant Access) whatever, it is, it is the buttons you're talking about.
I downloaded a driver from Server 1, Here, to get an Idea about your hardware. IF that link dosn't bring you to a site that says,
"Downloading Driver Canon CanoScan LiDE25"
then start here a few steps back, and find your model number in the list.
If you have the driver disc for this device, just use that,
if you have already done that,
find your scanner software on the Start Menu, and look for a configuration tool.
Hope this helps.
Posted on Dec 12, 2009
SOURCE: "warming up" all the time
Be careful fixing this problem with the firmware update version 0087 dated May 28, 2009. We downloade this update and installed it into the scanner. That fixes this issue but causes an intermittent issue where scanning stops and a "Lamp was over (-4430)" error message is printed. My workaround for this latest problem is to tell the user to turn off the printer, exit the Capture Perfect software, then run a script I wrote for him which stops and restarts the XP image capture service, then turn it back on and continue scanning. Canon tech support says it might be a USB issue but backed off that position when I mentioned it is intermittent, occurring on one out of 20 to 30 stacks of paper.
Posted on Jan 27, 2010
VBtoons
  • 28 Answers
SOURCE: HP5300C Cannot Find Scanner message from PrecisionScan SW
Does it show up in your hardware profiles? What does it say on details when you right click the scanner? When you installed the driver, was it before your plugged in the USB? You may have to uninstall and reinstall it again, this time use the one from HP's website with any patch if applicable.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=sj664en&lc=en&cc=us&dlc=en&product=58381&os=228&lang=en
If you have successfully used it in the past, follow the install prompts and restart.. instead of using the products software, use Windows included scanning program which is much better than the proprietary one designed by HP. As long as you have the proper driver installed your system will know how to apply it.
Posted on Feb 26, 2010
Where is the sensor lock switch?
The scanner lock is situated at the left side of the flat bed scanner. switch it to UNLOCK.
Sep 04, 2014 | Oki Brand Oki MB480 MFP Multifunction...
Oki mb 460 doesnt work!
Are there any lights at all? could be the hv power supply or the engine board.
Dec 07, 2013 | Oki Electric Industry MB460...
Can not open banks
I need to ask you this. Normally one bank can't be closed.
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
If that doesn't help. Please get it serviced. I do recommend to get a DSP Firmware Update for it. The download is free from RadioShack but the cable and software is not.
I hope this helps and solves this problem.
btw.. if you don't have the product manual http://support.radioshack.com/manuals/ome20-496.pdf
You will need Adobe reader or equivalent!!
Happy Scanning!!
Jan 21, 2013 | Radio Shack Pro-2096 Base Scanner
Can,t get scanner off all channels locked mode
Please try this!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
I have a radio shack pro96 i can not reboot it to restall the v scannfolder what can i do i have tryed everything to wipe it clean
Sounds like the motherboard is corrupted. Please try these steps again. Thanks!! Happy Scanning!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Apr 11, 2011 | Radio Shack Pro-2096 Base Scanner
I have A radio shack PRO-2096 and have not been able to use it in over A year. it reads all channels locked out. I can't unlock it.can someone please help me?
Please try this!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
May 19, 2010 | OKI B6500 Led Printer
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Need to know how to reset the oki c5400n to factory defaults
Procedure:
  1. Power ON printer while holding both the "+" and "-" buttons until “OKIUSER” message apear in LCD.
  2. Press ""+ or "–" button until “ENGINE DIAG MODE” is displayed
  3. Press "ENTER", will be displayed "DIAGNOSTIC MODE XX.XX.XX S-MODE"
  4. Press "+" or "–" button until “NV-RAM INITIAL” is displayed
  5. Press "ENTER" again
  6. Appear "TABLE 1" message
  7. Press "ENTER" until "EXECUTING RESET" message appears. "NV-RAM INITIAL" message will BLINK... IT resets TONER, DRUM, FUSER and BELT...
  8. Power OFF printer, wait 10 sec, and power ON again
To access Service Mode in C9300:
  • Power ON printer with 0, 1, 6, 7 at same time...
Nov 09, 2009 | OKI C5400 Laser Printer
On Oki C5600 printer with error message " Order k drum" and does not let me print. Can any one help how to reset and clear this message?
Try this procedure, don't know if it will work on your models.
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
Apr 12, 2009 | OKI C5500n Printer
147 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
