Question about Ovens
Bosch HBN 36.0 AU Clock works selector ok thermostat ok but no heat from oven or grill elements
4 Suggested Answers
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    Function selector knob loose
    contact the bosch service agent for spares
    Sep 03, 2017 | Bosch Ovens
    Bosch HBL 645 Convection Oven -- No Heat
    first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
    Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
    Tip
    Common heating faults with Bosch HBN 560570B / 560550B single oven
    For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
    To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
    2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
    3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
    4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
    on Jan 19, 2010 | Bosch HBN 560570B / 560550B Electric...
    Tip
    Common heating faults with Bosch HBN 430560B / 430520B single oven
    on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
    MAIN OVEN DOESNT WORK
    Hi
    Pretty certain nofuse. Suspect switch. Guess would be as element blew it took out contacts on oven switch
    Feb 20, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
    Dear customer,
  • Test the element
    Jul 08, 2008 | Ovens
    Tip
    Common heating faults with Bosch HBN 131560B / 131520 single oven
    on Jan 19, 2010 | Bosch HBN 131560B / 131520 hot-air...
    Tip
    Common heating faults with Bosch HBN 442 / HBN446 single oven
    on Jan 19, 2010 | Bosch HBN 442 / HBN446 Electric Single...
    No heat?
    hi there sounds like fan oven element at back, don't worry about smoke from grill is more than likley just grease burnning off element, just leave on for a min or two
    Feb 29, 2008 | Bosch HBN 131560B / 131520 hot-air...
    Fan oven not heating, bosch hbn 202t
    May 04, 2007 | Bosch HBL 5032 Electric Single Oven
    Ovens Logo
    64 people viewed this question
    Top Ovens Experts
    ashburton
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
