Question about Olympus WS-100 Digital Voice Recorder
I get a "full" message but it is not full
I have the WS-100 and I just deleted all the files.  Now it says "full" and it will not let me record. It is completely empty.  What did I do?
  • angelena2922 Jul 07, 2008
    Every time I try to record something it shows "full". I have erased all files. I don't understand why this is occuring. Please help!
Try this:
4 Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Posted on Jul 16, 2008
OLYMPUS Digital voice recorder ws-311m memory is full despite all folders being deleted
I had the same problem on a WS 311 and this worked for me as well, thanks so much!
Sep 19, 2012 | Olympus WS-311M Digital Voice Recorder
My WS 100 says FULL and won't either let me put it
The recorder should be formatted only by using the internal FORMAT function found in the recorder's Menu. Using a computer to format the recorder may corrupt or delete system files needed to run the recorder, so formatting via the computer is not recommended.
Individual files can be deleted from the recorder while it is connected to a computer without negative effects.
Feb 04, 2010 | Olympus WS-100 Digital Voice Recorder
My digital recorder wont work it says its full but
You will lose your data, but using the FORMAT command while not connected to a computer will restore the default settings and let it work again.
Aug 11, 2009 | Olympus WS-100 Digital Voice Recorder
Won't record, looks empty, but says it's almost full
Connect the recorder to your mac and empty the trashbin
Jun 20, 2009 | Olympus WS-300M Digital Voice Recorder
"No Format"
some of the dat files may have been deleted... try to retrieve those files. also formatting the recorder will clear the recorder of all files so you can start out new
Sep 26, 2008 | Olympus WS-100 Digital Voice Recorder
Copying to pc
copy and paste the files... dragging and dropping does not always work
Jul 14, 2008 | Olympus WS-100 Digital Voice Recorder
Problems caused by "improper device removal"
the recorder has .dat files in each folder and must not be deleted. if you still have them on your computer, then you can transfer back to the recorder and the recorder should work fine
Jul 03, 2008 | Olympus WS-100 Digital Voice Recorder
Erasing Files
when you copy the files to your computer the files are still in the ws-100, you have to erase them in the ws-100 buttons after that.
Feb 29, 2008 | Olympus WS-100 Digital Voice Recorder
"full" message
I had the same problem; see earlier post about record times. The "format" solution worked for me.
Dec 19, 2007 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100 Digital Voice Recorder Logo
261 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
