Question about Sansui Televison & Video
Hi my name in paul kraan and my frand has shorted out the output's of my sansui rz-4800 as a resoult it has blown the output ic part No : b688 would you be able to get me a replacment part number if there is one thank you
  • 901 Answers
Pl look at the IC and search in Google. Mostly Philips, Panosonic made IC would have been used. Check the complete no., printed on the IC.
Posted on Oct 05, 2010
RZ-8903AV no output
Audio amplifiers IC´s damaged
Mar 16, 2009 | Sansui RZ-8305AV Receiver
Please Help
First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Sansui DTV2760 27" TV
Tv is not wrking
Hope this may help;
Regards,
VOTIT
Aug 17, 2008 | Sansui DTV2760 27" TV
Sansui RZ 1500 II-Manual
i have the same problem but my receiver doesn't change sources and its blocked on the last station llistened. the problem appeared when i washed the face of the receiver with a special spray. i think that i have done something very wrong like a short cut in the command processor. any help, please?
May 25, 2008 | Audio Players & Recorders
Sansui amp problem
This sounds like you lost the 5V supply. If you can solder, look for bad solder connections around the voltage regulator ICs. These look like transistors (3 legs) and may be attached to a heatsink. They will be marked 7805 +/or 7905.
Dan
Mar 24, 2008 | Audio Players & Recorders
Sansui
I need a card with SMD ICs located on the circuit board of my sansui RZ6800 AV Reciever.(its a digital card with function IC and many more SMD components)
Sep 01, 2007 | Audio Players & Recorders
No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Feb 01, 2007 | Sansui RZ-5300AV Receiver
Televison & Video Logo
106 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
