Question about HP Office Equipment & Supplies
My printer keeps saying that there is a paper jam, but there isn't any and I cannot print out my essay
jaylex
  • 417 Answers
SOURCE: PRINTER SAYS PAPER JAM 23 ..
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
thanks J
Posted on Jan 12, 2008
frcs68
  • 1605 Answers
SOURCE: printer says paper jam, but no paper in there
use a flash light check all paper path, specially the area around the toner. all you need is a small piece or other (dust). There is a micro switch that detect the paper travel. so if anything preventing the switch to open, you will get error message.
after that, open the toner door, reseat the toner and close the door. the pirnter should return to normal.
Posted on Oct 23, 2008
SOURCE: printer keeps saying paper jam
we had the same problem at the college where i work. the print queue had somehow clogged up to such a point where the printer was doing this. the constant paper jam light & the printer taking paper when printing test sheets etc. we solved it by deleting the printer & then re-installing the drivers. may not work for everyone, but it certainly worked for us.
Posted on Mar 11, 2009
  • 34 Answers
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
Posted on Mar 14, 2009
pineworks
  • 4041 Answers
SOURCE: mY HP DESKJET PRINTER WON'T PRINT.iT KEEPS SAYING
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 13, 2010
Printer says there is a paper jam but there isn't
Please insure that the paper sensor flag is still in it position. Open the printer and look about in the middle to see the flag. Feel if it moves freely.
Mar 14, 2012 | HP Office Equipment & Supplies
My deskjet F2400 keeps saying paper jam, there isn't one. it will not print at all now.
One of the paper sensors most likely has dirt in it, Check the paper path and if you have access to an air compressor you can blow any dust out.
Mar 10, 2012 | HP DeskJet Office Equipment & Supplies
Last night I turned on my printer and printed out an essay and then turned the printer off. Today, I needed to print again and as soon as I turned on the printer it said that there was a paper jam and I...
Power off the printer. Disconnect it from the PC.
Power off the PC. Power on the PC, then connect the printer to the PC. Send a test page to the printer. See if it prints.
Aug 01, 2017 | HP Office Equipment & Supplies
I have a problem whit my printer i have a canon mx310 it keeps saying its jammed but its not how can i fix it
well when did u get it and were i have the same one maybe we could help each other. mine wont let me print my essays out my paper keeps getting stuck!!!!
Feb 19, 2010 | Computers & Internet
Canon iP 1600 printer won't print. Says that
Hi
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Feb 01, 2010 | Canon PIXMA iP1600 Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Printer keeps saying paper jam even after all doors are cleared of paper jam. Reset didn't work.
Dear, there is very minor mechanical fault but it is better to visit the repair shop to fix it.
Best regards
May 25, 2009 | HP Photosmart C6100 All-In-One Printer
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
