Question about Mitsubishi WS-55819 55" Rear Projection Television
I can't figure out how to contect extra devices, such as a play station portalble
I've tried to connect into all available ports, but with no luck. I just don't know how to do it.
  • allanz1 Jun 27, 2008
    I am trying to hook up my mitsubishi medallion and its not working
    Scholar:
  • 167 Answers
HELLO. CAN U TELL ME WHAT ARE YOU TRYING TO HOOK UP TO YOU SET.? GET BACK TO ME ASAP AND LET ME KNOW OK.
Posted on Jun 27, 2008
Bought sony bravia 32nx500 And i tried many hdmi. But whenever i connect my chromecast on any hdmi port it says "unsupported signal. Check your device output." Tried everything but still strugling..
Hi Tejinder,
There is a lot of variation in the HDMI cables available in the market. I also faced the same problem with an LG LCD and a Sony play station. I had an HDMI cord which I got with the HDMI converter fro the US, solved the problem. The other cords are working fine with the HDMI converter. I hope it helps.
Good Luck.
Aug 18, 2016 | Sony Televison & Video
Vizio Model M470SV HDMI port nor working (won't recognize dvd player,Xbox,play station etc)
This unit has four HDMI ports. Input is not automatically set to the port that your devices are connected to. Take a look at the markings that correspond to the port that your peripherals are connected to, then use the Remote Control to change the respective HDMI port.
With your external device connected and turned on, press the HDMI button on the Remote Control several times in succession until the proper HDMI port is displayed. Output from your device should now be displayed on the screen.
Nov 27, 2014 | Vizio Televison & Video
Will a kensington universal docking station work with my sony vaio pcg-7d2l
Yes it should if you are running Windows XP, Vista, 7 or 8. You just connect to the unit using a spare USB port on your laptop and a plug-plug USB cable. It has it's own power so you'll need a mains socket. This means you can unplug your laptop and leave any devices charging on the docking station USBs. Your laptop should auto-instal the station. I believe there is a table/support available which combines with this unit. There a varying prices for this unit so look around.
Good Luck
Feb 27, 2014 | Kensington SD400V USB Docking Station with...
Unable to connect PS3 to linksys wrt300n, key exchange timed out, signal 100% and key is correct?
For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 08, 2012 | Linksys Wireless-G WRT54G Router
How to install RCA streaming media player on an old TV
I've had a quick look at some instructions online, can't be sure if I'm looking at the same device as you but.
Guesstimating, you're connecting via the composited A/V jack out from your box to RCA (red,yellow,white) inputs on your tv. Or the same but using a SCART converter.
If so, once you've turned it all on, you probably have to change to the correct AV input on your TV. Just keep pressing the AV button on your TV remote control, it should cycle through all the AV inputs until it gets to the one you require.
Apr 28, 2012 | Audio Players & Recorders
The little pieces that connect the upper rotor to the fly bar, are broken. Are those called Buckle Bars? Where can we find some extras?
We've had this problem on one of our three Sharpshooters. I've contacted Air Hogs about the issue and replacements for that piece are NOT available from them. I've had some success using fine wire to resecure the connections by wrapping the end of the little piece that breaks and then wrapping the wire around the little tip on the upper rotor where the piece formerly attached. Good luck!
Jul 26, 2011 | Master Heaters Air Hogs Sharp Shooter...
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
I have an Archos 605 WiFi. I haven't yet connected my Archos docking station to the TV and HDD. Meanwhile, I thought I would copy a programme from the HDD to a DVD, then put the DVD in the computer and...
What kind of HDD do you have, do you have any type of output on it. You stated that you haven't connected the docking station to it and the TV...? The best thing to do is to connect your Archos to the Docking station. Set the docking station up correctly, with cables coming out of the HDD (if it has some sort of output) to the station and out of the station to your TV. Once you set that up, you can use the Archos as a mini DVR or VCR. Go to the REC option on the main screen of Archos, you'll have an option for Video Recorder (tab on top). If you play any source on the HDD, then all you have to do is press the Rec option on the Archos. If you already have a file on the HDD, then try just moving it over into the Archos once you connect the Docking station to your computer via USB or just use the USB cable connected to the computer with the HDD. I use the USB preference as Windows Media Device. (found under menu/settings/system). Is is basically a HDD itself. Remember the Archos will only play certain videos without the purchase of any extra plugins.
Good Luck
Apr 14, 2008 | Archos 605 WiFi Digital Media Player
Usb port dont work
Usually issue might be BIOS and Chipset related
first of all ensure if your BIOS is up to date, latest released version is Flash BIOS v1.3505, If yours is below this update the BIOS
next step will be updating the Chipset (Intel Chipset driver v8.0.0.1009)
Both of the drivers are available. I am adding the direct link for your convenience. Here is the link;
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=5924616&CFTOKEN=73863150
Please post more if you need further assistance.
Good Luck
Jan 10, 2008 | Acer Aspire 5100 Notebook
Mitsubishi WS-55819 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
