Question about Eemax EX380T2T2 Series 4 Whole House Electric Tankless Water Heater
My house has 200 AMP Service, will this work ok with the EEMAX EX380T2T2? It requires 4 40AMP Breakers.
    Problem Solver:
  • 6 Answers
Your water heater will take a 160 amps of you service. I would not install one if it was me. The total demand in the dead of winter with furnace, water heater and lights on will cause you to brown out.
Posted on Oct 06, 2010
I have a Eemax so 35 instant water heater and it makes a buzzing noise when you turn the hot water on
Heavy current required for instant hot water may be switched via a relay or contacter which may be faling. One way to diagnose may be with cover off and careful listening and visual inspection, but a risky process for inexperienced DIY'er's ??. Pro time?
Apr 11, 2017 | Eemax Water Heaters
Eemax280t2t no hot water
see if the circuit breaker switch has tripped either partially or fully and reset it. Check for bad or loose wiring on the heater and breakers. The next thing is more likely the heating element is no good and needs repaired or the heater needs replaced.
Jan 30, 2014 | Eemax Water Heaters
Powerstar model 45557701
Copy following link:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
AE115 has two elements and requires two 40 amp breakers.
A#125 has three elements and requires three 40 amp breakers, and is considered 'whole-house'
Do not install a tankless water heater because they cost more to install, and cost more to operate and maintain..
Add a comment and ask question.
Jun 21, 2013 | Water Heaters
Have Model EX380T2T2 Serial # 777604. Have purchased two EX630 heating elements and installed them. Water got hot for about a week. One more old heating element burned out. Fixed it by reattaching to...
A lot of problems can contribute to this problem.
As you know, tankless cannot be exposed to water with more than 11 grains of hardness.
Tankless require softener and filter system which can affect line pressure and flow, which will adversely affect tankless unit.
The problem could be clogged sensor, bad board, but still that doesn't explain burned out elements unless the elements were coated with sediment.
Sediment build up will kill a tankless within 2 years and render it useless and unfixable.
Yearly deliming will not restore functionality.
If pressure is a contributing factor, you can add a pressure tank that will even out the pressure.
All in all it looks like the pressure sensors and other sensors are crashing.
Call service technician, and glean from that person the tips and tricks.
Read the manual for advisories and required yearly maintenance.
You can fix this tankless problem yourself, same day, by installing $207 tank-type electric water heater from box store. Offer 10% less and also buy flexible connectors to connect to existing water lines. The cost of running and maintaining electric tank-type is cheaper long term. All costs are energy.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
May 01, 2011 | Eemax EX380T2T2 Series 4 Whole House...
The center heating element is no working. How much does a replacement element cost?
the price will vary in different localities.
you should call a plumbing wholsaler in your area. Home depot and Lowes will not carry these, neither will you local hardware store.
the replacement is faily simple. Eemax is a nice heater, although faily expensive to opperate.
Aug 20, 2010 | Eemax EX280T2T Series 3 Whole House...
Fluctuating tempture during showers. how can this
if you have a low flow shower head this could be the problem have seen it many times before try removing the restrictor and try again
Feb 28, 2010 | Eemax EX380T2T2 Staged
No hot water
in and out hooked up right?
May 17, 2009 | Eemax EX280T2T Series 3 Whole House...
We are currently updating or eemax heaters with the newer control
have you tried eemax.com go to customer service lititure request... they also have a tech support number... if you need more help feel free to contact us as sales@heaterup.com
Apr 11, 2009 | Eemax SP4277 Single Point Electric...
Eemax EX380T2T2 Series 4 Whole House Electric Tankless Water Heater Logo
146 people viewed this question
Top Eemax Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you an Eemax Water Heater Expert? Answer questions, earn points and help others
