Question about AudioBahn A2002T Car Audio Amplifier
When i turn the amp on the blue light turn on then turns off right away. and the amp will not work any more. now i have noticed that the fan was makeing some noise about a week prior to this hapening."would the hole thing stop working to protect its self " is it as easy as replaceing the fan??? i have taken it apart and i dont see any thing wrong, nothing apperas to be burnt, and i dont see any shorts
  • 30 Answers
Primero que nada debe revisar que el parlante olos parlantes esten bien, deben ser medidos con un multimetro en medicion de homnios y deben medir mas o menos de 4 a 8 homnios,revisado esto,y si esta bien entonces debe haser revicion interna de la planta pudiendo ser salidas dañadas y la causa depende de por ejemplo de como se instalo,si los cables de voltage estan bien,si el porta fusible no esta fundido,oel fusible quemado , si la linea a tierra esta bien sujetada,y si todas las amarras de cable han sido soldadas,revisado todo esto entonces no queda de otra que revisar la planta por dentro por un experto revisando transistores,mossfet y componentes alrededor
Posted on Oct 05, 2010
    Problem Solver:
  • 4 Answers
Have you checked all the fuses and wires?
Electrc trailer brake wiring schematic
Not knowing the year or model makes this impossible to answer.
Dec 28, 2013 | RVs
Fan just quit working one day. Nothing happens when I turn the light switches on and off.
Is it powered thru a light switch? Sometimes those do just quit. You can remove the old switch & replace it. Go to Lowe's/Home Depot, the switch itself is fairly inexpensive (probably less than $5). Remember to turn off the breaker to that room/switch before you do anything. The installation itself is simple - just wire + to + and ground it. Did you notice any kind of noise/smell before it stopped working? If the motor is burnt out - just replace the whole fan (unless you feel like tinkering with breaking it down & finding a replacement motor). Sometimes the lite switch on the fan itself will go out - parts for that can be found at about any larger hardware store, but sometimes that's not an easy repair (depends on what type of lite kit is on the fan). However, if that were the problem -it would not cause the blades not to turn, it would only keep the lights from coming on. Try replacing the light switch that turns the fan on/off first (the one on the wall, not on the fan itself) - hopefully that'll solve it for you. Good Luck.
Jul 13, 2011 | Hunter Fan 21623 Concert Breeze Ceiling...
Blue light on top flashing???not powering subwoofers.. was working fine.( blue light stayed on.) When I noticed it I shut the system down immediatley!!! Have'nt turned sytem back on since. What should I do...
You amp went into protect mode from an abnormal condition. Were you hammering on this amp when that started? I might suggest letting up on it a bit if so. Also check your wiring. Make sure all are insulated well and fully connected. It cut the noise off because if it would have continued it would have blown your amp. Make sure the fuse is good as well. Perhaps it is getting weak. Turn things down and turn the amp on. Give it a chance to cool for a bit first and then turn things down and turn it on. Everything a go? Then turn it up a bit then. My guess is it was getting worked a bit to hard and went into protect mode. Give the amp a rest from time to time. Good luck.
Mar 06, 2011 | Pioneer Car Amplifier GM-7100M - Mono Bass...
Dodge charger fuse box , where the fog lights relay goes ?Thanks
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
if this helps please rate 4 thumbs up.
Jan 21, 2011 | 2007 Dodge Charger SRT8 Sedan
Cant calibrate tony hawk shred board to my wii. I've tried everything
At last! My Son's Tony Hawk Shred board was one more try from being thown down the garden, as i have been trying since Christmas day, & finally there it was a board i could use. I've followed all bits of advice in a number of differant ways --- here's what worked for me, Turn off at the wall Sky TV, Turn off all lights (only tv turned on), put my crutches in another room (because large metal objects interfere with soft ware), Remove dog from room, Put senser bar on floor, Turn Wii console side on so that Dongle faced away from tv (aiming into centre of room), Place Shred board on floor facing tv/senser at about three feet away. Start process of game set up untill you get to choose a profile, Select profile, press & hold for 5 secs start button on board untill the four blue lights start to flash at a rate of about one flash per sec, then hold on same button untill blue lights flash quickly, then press & hold Dongle button untill Dongle light stays on, with in 2 secs game calibartion instructions start, BEWARE Tony Hawks responce when process starts is as annoying as not being able to get board started. Good luck when up & running it is one Awesome game!
Jan 01, 2011 | Activision Tony Hawk Ride for Nintendo Wii
When i turn my ac on in my kia it overheats. when i turn it off, it immediately cools down. What do i do?
Sounds like a/c condensor fan not turning on. It should turn on right away as soon as you turn a/c on. If not check fuse, relay, power & ground to fan &/or fan motor.
Jun 24, 2010 | 2002 Kia Sportage
Flashing blue lights
toss it. learn from it. Use Consumer Guide or something similar. Thank god it fots down the incinerator duct.
Jul 28, 2009 | Sharper Image Professional Plus Ionic...
AudioBahn A2002T Car Audio Amplifier Logo
145 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
