I just switched out the batteries, turned on the calculator and all I see is line across the screen.
  • 30 Answers
Puede ser que las baterias viejas se hallan deramado probocando cortos circuitos y debe desarmar y limpiar las terminales de baterias la tarjeta interna tambien debe ser limpiada con limpia contactos que se venden en tiendas electronicas
Posted on Oct 05, 2010
When I press ON, my calculator screen displays a couple random numbers and letters scattered across the screen, including a solid vertical line in the upper right corner. As soon as I push any key, the...
There are three possible solutions here. From what you are describing to me, you say the screen displays a couple of random numbers and letters, including a solid vertical line in the upper right corner, are scattered across the screen? Sounds like you are still in graphing mode. There is nothing wrong with your batteries and changing them won't help because I already know that you didn't change the CR Lithium Battery. This is the "memory card" for the TI-83 Plus. If you don't change that, when you insert new AAA batteries in the calculator, the memory has not been deleted. You probably don't remember, but the calculator remembers the last problem that you did, which was a graphing calculation. Try pressing the "Graph" button and the calculator will go back to function mode. If this doesn't work, try resetting all the memory.
  1. Remove a battery from the battery bay.
  2. Press and hold the CLEAR button while re-installing the battery.
  3. While still pressing the CLEAR key, press and hold down the ON button. If the home screen displays, release the keys.
  4. If the home screen is displayed, press 2nd MEMto display the memory menu.
  5. Select 7:Reset to display the "RAM ARCHIVE ALL" menu.
  6. Press the right arrow twice to display the "ALL" menu.
  7. Select 1:All Memory to display the "RESET MEMORY" menu.
  8. To proceed with the reset, select 2:Reset. The message "MEM cleared" is displayed on the home screen.
If this doesn't work, try changing the CR Lithium Battery. It is located in the battery bay at the top with the cross-head screw in it (It says BACK-UP BATTERY). It tells you what type of battery it takes and how to insert them in. I hope these possible solutions help. If all of them don't, then the only other thing I can think of is that it has some internal part alignment issues or a cold soldering iron blob, on the inside of the calculator. I saw one time on the Internet that cold soldering irons can sometimes make electronics not work properly.
Jan 14, 2011 | Texas Instruments TI-83 Plus Calculator
I have a TI-83 that hasn't been used for a couple of years. I replaced tha 4 AAA batteries, turned on the calculator, but the screen just displayed one horizontal black line. I couldn't get it to respond...
Hope is what keeps the world turning.
Clean the electrical terminals even if they seem shiny. Use a clean eraser tip of a pencil.
Insert the main batteries.
If you see the line again, press [CLEAR] to see if it disappears.
Try resetting the RAM by pressing [2nd][MEM][7:Reset][1:All Ram][2:Reset] [ENTER][ENTER].
If screen is too light or too dark, adjust the contrast:
Press [2nd] key and release it
Press and HOLD Arrow (UP to darken, or DOWN to lighten) the screen.
If that does not solve the problem you may have to force the calculator to boot up. Details are in the article . Read the part on Ti83Plus family.
The article contains links to additional articles.
Hope it helps.
Oct 29, 2009 | Texas Instruments TI-83 Plus Calculator
One horizontal line across the screen
Read this article for troubleshooting.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
Blank lines across the screen of a TI-86 graphing calculator
Try this, hook up new battery and go to MODE and darken and lighten the screen.. do it ten to fifteen times. if that doesn't help, try hook up most left and most right's battery terminal to a DC supply at 4.5V. dont go above 4.5 it will fry your calc (it is design to handle 3V). now you are forcing extra juice into the dead LCD screen lines... and reapeat the MODE + darken trick. I fixed mine like that! Works! and remeber to leave it completely black(darkest) for a while to keep that dead line alive!
Jul 06, 2009 | Texas Instruments TI-86 Calculator
When I turn on my Ti-86, there are two lines across the screen
Try to reset the RAM. [2nd] MEM and select Reset.
Hope it helps.
Dec 01, 2008 | Texas Instruments TI-86 Calculator
Line across the screen
If it's just a single line then it sounds like that the screen is not connected probably or is shot...
if it's more of a "flurry" or snow... then you can connect to another unit via the I/O cable or usb if your model has it, and use the "send OS" command to start from scratch and lose all data but have a working calculator.
Feb 07, 2008 | Texas Instruments TI-83 Plus Calculator
Won't power up, flat line across screen - battery problem?
Yes, this sounds like you'll need to replace your back-up batteries. That will probably resolve the problem.
Aug 03, 2007 | Texas Instruments TI-85 Calculator
Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Jan 17, 2007 | Texas Instruments TI-83 Plus Calculator
Calculator Stuck
Hi. I suspect your calculator BIOS is corrupted. Still looking for the download for that though. Do you have a USB link cable? If so, plug in your calc and check your device information. See if anything comes up.
Dec 08, 2006 | Texas Instruments TI-83 Plus Calculator
64 people viewed this question
k24674
jasbo
jasbo
