Question about True Freezer TG2F-2S
Refrigerator get icy every 4 to 6 week - True Freezer TG2F-2S
  • Dennis Boxerman Oct 06, 2010
    Is this a refrigerator or a freezer. You info is indicating both. Please clarify and I can try to help.
  • John Ansari Oct 06, 2010
    This is Freezer.
  • True Master
  • 1,078 Answers
Since your symtom is general, I'll answer as such.
An air leak due to doors not sealing can cause general icing. A defrost cycle that is too long can cause icing in areas other than the evap. A defrost cycle that is too short can cause evap icing. Intermittent problem with the evap fan. Overloading the unit with too much product can restrict air flow and cause icing. Door not closing due to spring loaded door closing hinge not working correctly.
I'd start with some of these suggestions to see if we can get you in a direction.
Your freezer should be able to handle a minus 5 to 10 degrees, generally speaking.
Posted on Oct 07, 2010
Testimonial: "Thanks you so much. I hope it will resolve me problem. "
  • 98 Answers
1. reduce the Thermostat switch and see.
2. There can be a air leak from the door gasket.
Posted on Oct 06, 2010
My upright freezer get icy all the time.
Check the rubber seal around the door edge is correctly fitted.
If you need to adjust the hinges and level your freezer
Clean the seal and then smear a small quantity of vasaline over the seal.
If it keeps icing, you may have to replace the seal
Hope it helps
Feb 03, 2016 | Freezers
Used wrong water filter. Now that we replaced with correct filter, there is a horrible odor in the refrigerator.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Try Lowe's and Home depot.
May 11, 2015 | Samsung RF31FMEDBSR Stainless Steel 31 cu....
Very bad smell coming from my Samsung refrigerator
most refrigerators have a small drainage hole leading from the inside rear of the compartment to an overflow container behind the unit, pull the unit away from the wall and check if the liquid in the container has become stagnant, if so simply clean it out and run a small amount of bleach down the hole to disinfect the tube.
hope this helps.
Nov 11, 2013 | Samsung RS261MDWP - 26 cu. ft. Side by...
Kenmore Freezer 106.727581: The freezer ices up and the temp goes up to 34 degrees. If I manually defrost it, it goes to 5 below zero in about 6 hours. How can I determine which of the below need to be...
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater. To determine if the defrost heater is burned out, watch this part testing video
Aug 21, 2011 | Kenmore Freezers
My old lec elan upright freezer is not freezing, it has been switched off and in the garage over the summer. It has been switched on for a week with the control at 6. It is only down to -4 degrees C....
It sounds like corrotion in the piping has created such a fine leak eg Pourous Piping Letting Most of the refrigerant escape.It woud be advisable to condemn the freezer as even if patched up it would be un reliable causing a loss of money ror repairs and loss of food.Hope this helps.
Dec 13, 2009 | Freezers
Freezer wont freeze, compressor always running, refrigerator not cold
HI,
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Jul 03, 2009 | Traulsen Freezer Refrigeration 4 - 1/2...
Vegetable or fruit do not remain fresh they decay within a week
whats is the refrigerator temperature that you are running, it should be around 34-36 degrees inside of the refrigerator. also wqhat is the humidity levelthat you are running in the vegetable crisper? that shoupld be on highest setting for humidity.
Jan 13, 2009 | Freezers
True Freezer TG2F-2S Logo
137 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
