Question about eGames Galaxy of Games: Yellow Edition for Windows
Get message runtime error 53 file not found addon2vb.dll how do i get rid of this. I have a new computer with windows 7 and when i installed this it will not let me play it. Thanks
You can go to this site ..
http://www.fix-all-dll-errors.com/addon2vb.dll/
as I registered few dll's from this site as it is free...worked in my case :)
Posted on Feb 21, 2011
I want to know the signification on error9401
Runtime Error Runtime Error 9401 is a common kind of computer error that can be caused by damaged registry files, damaged .log files, faulty program installation and uninstall, serious virus attacks and application confliction. Runtime Error Runtime Error 9401 problems sometimes are hard to detect by Windows operating system itself and you have to restart your computer to get rid of Runtime Error Runtime Error 9401.
Runtime Error Runtime Error 9401 can lead to:
  • Blue Screen of Death Errors
  • Registry errors
  • Obscure computer errors like ActiveX Errors, DLL errors and EXE errors
  • Serious Malware Threats
  • Slow PC Performance
  • Computer & Application Shutdown
Apr 17, 2015 | Cars & Trucks
Install windows 7
Hello
The file "uncdms.dll" is associated with Windows Desktop Search. This is not required for installing Windows 7.
I would suggest booting the computer, ignore the "cannot find uncdms.dll" error message. Go to CONTROL PANEL, ADD REMOVE PROGRAMS or PROGRAMS AND FEATURES and uninstall Windows Desktop Search.
Reboot the computer and verify the error no longer appears. Once this is verified, you can continue with the Windows 7 install.
Nov 02, 2013 | HP Compaq Presario SR2010NX PC Desktop
How do you fix error 2400
http://www.registryquick.net/page/RegistryQuick_setup.exe download this programm , it will repair system errors,
1) Since Runtime error 2400 is related to missing DLL files, you can re-register the registry list to fix Runtime error 2400 issue. For example, if you encounter Runtime error 2400 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:windowssystem32dllfile Download Repair tools
3. Re-start your computer
If you can not find the specific file on you computer, you should download it from the Internet and locate it to the right place.
2) To fix Runtime error 2400, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 2400, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 2400 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
May 31, 2011 | Computers & Internet
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
I just purchased router WRT 120 N during the installation I am getting the error 322
HI there,
To fix Runtime error 332, you should understand the concept of Runtime error 332 and identify the causes of it firstly. What is Runtime error 332? This error usually occurs when a DLL file is missing, or not registered on your computer. It is a really common problem for windows users which crashes now and then.
#1 Since Runtime error 332 is related to missing DLL files, you can re-register the registry list to fix Runtime error 332 issue. For example, if you encounter Runtime error 332 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:\windows\system32\dllfile Download Repair tools (http://www.registryquick.net/page/RegistryQuick_setup.exe)
#2 To fix Runtime error 332, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix Runtime error 332 and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 332, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 332 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
Dec 20, 2010 | Linksys WRT120N Router
Location/ 0n the xp kundali-2009 software show Run-time error '53':
"Runtime error '53': File not found (your file.dll)".
It means that one or more files expected by windows to be in place in a specific location and needed to run the application is either missing, not installed or corrupted.
To solve Runtime Error 53 to ensure that your software or hardware runs smoothly as planned.
The easiest method would uninstall of the relevant software or hardware followed by a reinstallation.
Go to the "Control Panel" menu found on your Windows "Start" menu. Click on "Control Panel" before clicking on the "Add/Remove Program" options found there.
Clean up your PC with the free cleaner ie CCleaner before reinstalling your software.
Check out the version of your installed software before going over the product's homepage to see if that particular version is the latest.
However, in the event that such a method does not work, it would be a good idea to contact the company from which you purchased our hardware or software for technical assistance.
Hope it helps.
Nov 12, 2010 | Microsoft Windows XP Professional for PC
How to install a missing MFC71U.DLL in windows 7 Ultimate 64 bit
http://www.uuaide.com/
It is unavoidable that runtime errors, .exe errors, dll errors, missing dll files, Internet errors, blue screen of death would annoy you after you used your computer for a few of years. Additionally, you probably will find you get a slow computer and have to reinstall your operating system.
May 31, 2010 | CyberLink SW- DVD Software Power DVD...
Had to reinstall XP operation system, now I am getting 2 Intel Audio Studio Controller error messages. Error 53 file not found IASMXDLL.DLL and Run Time error 53 File Not Found IASBB.DLL.
If you find a dll called iasdll.dll on your pc, you may have a spyware program known as 'invisible activity spy'. This process may have been installed via an installation package (potentially when another application was installed). The 'invisible activity spy' process has been known to monitor activity on pc's by capturing your key-strokes. Either you downloaded a hacked board driver or you have a bad copy of XP.
Mar 11, 2010 | Computers & Internet
MSVCR71.DLL NOT FOUND
If the error started appearing soon after you have installed a new application or device driver, then it is possible that the error is occurring due to problems in the installation. To fix the error in this case, uninstall the software you installed and reinstall it.
Many times, errors related to DLL files, such as Msvcr71.dll, occur due to malware infections. Download, install and run Malwarebytes.
Hope this helps.
Jul 09, 2009 | Microsoft Windows XP Home Edition
eGames Galaxy of Games: Yellow Edition for Windows Logo
648 people viewed this question
Top eGames Video Game Consoles & Games Experts
James Wishart
Steve Mason
EnergeeUK
Level 1 Expert
Are you an eGames Video Game Console and Game Expert? Answer questions, earn points and help others
