Question about Mercury P4VM800M7 Motherboard
I have installed sound drivers but no sound is heard from the speakers the playback devices shows no jack information shown .the mic and line in ports are working.
  • Mercury Master
  • 27,725 Answers
Control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Oct 05, 2010
My computer speakers stopped working after installing Logitech quickcam deluxe for notebooks. Please help.
Run an audio check
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 28, 2010 | Logitech QuickCam Deluxe for Notebooks
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
People cannot hear me
If your webcam has a built in mic make it the default mic
XP
Plug in your webcam
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your webcam mic the default device in the 'Sound recording window'
Vista
Plug in the webcam
TEST SPEAKERS
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
Restart computer
Configure your webcam to the chat program
Aug 22, 2010 | Logitech Webcam
How to install the mic on this
Depends on your OS
If you have XP do it from the Control Panel (Classic View)
Plug in your webcam
Vista
Plug in the webcam
TEST SPEAKERS
Restart computer
Aug 21, 2010 | Logitech QuickCam Communicate Deluxe...
Cannot get sound is there a switch to put sound on
Plug in the webcam
TEST SPEAKERS
Restart computer
Aug 12, 2010 | Logitech Quickcam Chat Webcam
My mic is not working
Logitech QuickCam Communicate STX WebcamThis webcam does not have a built-in mic
To check
Plug in the webcam
TEST SPEAKERS
All available mics on your computer will show here
Right click on a mic and check the box to show disabled mics
Restart computer
Jul 31, 2010 | Logitech QuickCam Communicate STX Webcam
Terrible sound
You may need a headset if 'feedback' is a problem
Check your webcam mic is set as default.
TEST SPEAKERS
Restart computer
Configure your mic/ webcam to the chat program of your choice
May 24, 2010 | Logitech QuickCam Pro 9000 Web Cam
Logitech quickcam pro 9000. computer does not recognize the microphone. Under devices, not enabled & no drivers, I enable & download drivers, but still no mic. picture great. all other sound...
TEST SPEAKERS
In lower dropbox display "Use this device enable" click OK
Restart computer
Configure to your chat program
Feb 02, 2010 | Logitech Webcam
Mic is a piece of ****. Lots of Comments about this but ZERO anw
do you have the Mic plugged into the mic jack on the sound card? and in is it plugged into the mike hole as there are up to five depending on the sound card. also slick on start click on control panel click on device manger and look to see if you have a yellow ! on the mic or unknown sound device if so left click on that device while on-line and update drivers on the web, if it does not show a mic or one that's ok double click on the sound or speaker control when the sound system pops up make sure the mic is not muted and recording device is turned on if not delete the mike from the device manager and have it detect it again and then install updates form the web, any more questions post a comment here and I will help you some more. need to know the sound card and what operating system you are running.
Jun 17, 2009 | Altec Lansing AHS302i Headset
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Mercury P4VM800M7 Motherboard Logo
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
