Question about Janome Memory Craft 9000 Computerized Sewing Machine
I have a Memory Craft 8000. The computer screen seems fine. I can push all the buttons and the screen changes. However, when I have pushed the zig-zag button(stitch #4), the machine will not make a zig-zag stitch. It just sews a relatively straight stitch. No amount of changing the length and width of stitch will help. Can anyone help?!
  • mtclouds Oct 05, 2010
    i have already tried recalibration after i read about it on another site. this did not help, but thank you for anwering.
  • mtclouds Oct 06, 2010
    it does seem to zig zag a very tiny bit. do you mean that i should actually lower the needle in the needle clamp? i will try this and then look for a tiny alan key if i need to. thanks
  • 22,326 Answers
The mechanism is worn that makes the needle head move in a zig zag fashion ,need to be taken to a repair man to have the worn parts renewed
Posted on Oct 06, 2010
  • 2,272 Answers
Does the needle alternate position in a zigzag motion? If it does then the problem might be your timing. In order to fix it you would have to set the timing on the hook and needle. If the needle bar does not move in a zigzag motion then your zigzag settings are off or the mechanism is faulty.
Initially try putting the needle down a little (like 1mm) either at the needle end (temporary) or loosen off the post (you might need tiny alan key?) and let it go down a tiny bit - be careful to mark original spot before loosening off
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 05, 2010
  • 3,530 Answers
Try to recalibrate the machine.
With the machine off Hold down the three buttons that are on the front of the machine(start/stop.reverse and auto lock). While the buttons are depressed turn the machine on. A box with the sign + will come up on the screen under it you will see another + that is the one you touch. Then several more + come up.
Just touch each one as they appear. Then the message test complete will come up. Turn off machine and wait at least 5 seconds. Then you can turn the machine back on and hopefully fixes your problem. It checks for errors and fixes them.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
My Janome memory craft 8000 will only sew backwards and the screen shows step motor error. the machine is 19 years old. Is this fixable?
step motor error may mean the embroidery arm is out of position gently push it back home towards the machine and see if this helps. If the mother board is gone, they will not be able to replace it as its so old, but you may be able to get an 8000 or 9000 on ebayso you can still use your discs if you don't want to get a new machine
Aug 09, 2010 | Janome Memory Craft 9000 Computerized...
Memory craft 8000 how do you take it apart to replace light
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Jun 22, 2010 | Janome 8080 Computerized Sewing Machine
Screen dull on Janome mc 8000
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light
Janome Memory Craft 8000 LCD Backlight Replacement Kit
Mar 26, 2010 | Janome Memory Craft 5700
Changing light bulb on Memory Craft 8000
Check this Link
Feb 05, 2010 | Janome Memory Craft 9000 Computerized...
Need touchscreen backlight for merory craft 8000 janome new home
Check this Link
Dec 09, 2009 | Janome Memory Craft 9000 Computerized...
The sewing advisor screen on a Janome 8000 is getting dim.
Check this Link
Jan 26, 2009 | Janome Memory Craft 9000 Computerized...
Janome/New Home Memory Craft 8000
I have a memory craft 8000 that gets a message stating "Stepping Motor Error". What can I do to try to fix it?
Oct 01, 2007 | Sewing Machines
Janome Memory Craft 9000 Computerized Sewing Machine Logo
116 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
