Question about Fisher Paykel EcoSmart GWL15
Water will not pump out - Fisher Paykel EcoSmart GWL15
  • Fisher Master
  • 713 Answers
Hi just read your posting.Now 1st thing to do is to drain some of the water by hand with a small bucket or pot ,enough so you can look under the machine for me.Now when you can look under the machine look to the front right and you should see a black fan.This is your pump.Please reply if you can see a fan or if your machine has the newer type of pump which has no fan.Once I get this information I will guide you step by step to rectify this fault.Looking forward to your reply.
Posted on Oct 05, 2010
Replace water pump torrent
drain coolant until below water pump level. loosen water pump pulley bolts.then remove drive belt by rotating belt tensioner.remove drive belt from the right of idler pulley.carefully release the drive belt tensioner spring tension.then remove water pump pulley bolts and pulley.remove water pump bolts and water pump pay attention to the position old water pump when removing water pump so you can line up new water pump holes to the engine. be sure clean engine water pump mounting surface use gasket remover dont scratch engine surface when cleaning removing old gasket material. take new water pump gasket get it mounting holes line up with new water pump mounting holes.when done getting engine water pump surface clean.water pump gasket paper you need to put thin layer of sealer on both sides of water pump gasket use RTV SILICONE.LET SET UP 10 MINUTES. PUT GASKET ON WATER PUMP BUT FIRST MAKE SURE LINE UP GASKET HOLES WITH WATER PUMP HOLES BEFORE PUTTING ON THE GASKET SEALER.when gasket sealer set up 10 minutes then install new water pump with gasket to the engine torque to 89 inch lbs.or 10 NM that is about 7 ft lbs torque.you should be able turn water pump by hand if you cant turn water pump by hand got too tight damage water pump shaft bearing.when all done wait for THREE HOURS. before adding coolant i let RTV CURE SOME. torque water pump pulley bolts 18 ft lbs.
Dec 28, 2012 | 2006 Pontiac Torrent
Water pump
Which engine?
  1. Drain the radiator
91192665
  1. Loosen the water pump pulley bolts.
  2. Remove the serpentine belt.
91192666
  1. Remove the water pump pulley bolts and pulley.
  2. Remove the water pump bolts, pump and gasket.
  3. Clean the water pump mating surfaces.
Installation Procedure
  1. Install the water pump gasket and pump.
91192667
  1. Install the water pump bolts. Tighten the water pump bolts to 89 inch lbs.
91192668
  • Install the water pump pulley and bolt until snug.
  • Install the serpentine belt.
  • Tighten the water pump pulley bolts. Tighten the water pump pulley bolts to 18 ft. lbs.
  • Fill the cooling system and purge of air.
  • Inspect for leaks.
  • Sep 27, 2012 | 2001 Oldsmobile Alero
    How to tighten a water pump on a 1990 oldsmobile 88 royale
    For water pump replacement i suggest you to check the help link provided below.
    click the link below :----
    Water pump replacing procedure for all vehicles?
    http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
    HOW TO REPLACE A WATER PUMP
    http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
    How to route Water Pump Belt for 1992 Oldsmobile ?
    http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
    How to replace Water Pump on Car ?
    http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
    How to Remove Water Pump?
    http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
    Where is Water Pump located ?
    http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
    This will help. Thanks.
    Feb 14, 2012 | 1990 Oldsmobile Eighty Eight
    How to replace water pump infiniti m35 2006
    Feb 12, 2012 | 2006 Infiniti M35
    Replace a water pump on a 1992 mercury topaz 4 cylander
    Feb 04, 2012 | 1992 Mercury Topaz
    Change the water pump
    • Tools Required
    • J 43651 Water Pump Holding Tool
    • Remove the thermostat housing.
    • Remove the water pump access plate from the front cover.
    • Remove the right hand fender liner.
      1. Important: A drain plug has been provided at the bottom of the water pump assembly for additional coolant drainage from the engine block and water pump.
      Drain the coolant from the water pump using the plug at the bottom of the pump.
      1. mportant: The water pump holding tool supports the sprocket and chain during water pump service. The tool must be used or the balance shaft must be re-timed.
      Install the J 43651 into position.
      1. Tighten the bolts on the water pump holding tool into the threads on the water pump sprocket.
      2. Install the access cover bolts that were removed earlier to secure the water pump holding tool to the front cover assembly.
      3. Remove the 3 inner water pump sprocket to water pump blots.
        1. Important: Be sure to remove both water pump bolts from the front of the engine block.
        Remove the 2 water pump bolts.
        Remove the rear 2 water pump bolts.
        1. Remove the water pump.
        2. Remove and discard the water pump O-ring seal.
        1. Important: Prior to installing the water pump, read the entire procedure. This will help avoid balance shaft chain re-timing and ensure proper sealing.
        Install a NEW water pump O-ring seal.
        1. Important: A guide pin can be created to aid in water pump alignment. Use a M 6 m x 6 mm stud. Thread the pin into the water pump sprocket.
        Using the guide pin, align the pin with the water pump holding tool.
        1. Position the water pump against the engine block and hand tighten the water pump bolts.
        2. Notice: Refer to Fastener Notice.
        Install the inner water pump sprocket bolts. After 2 are snug, remove the guide pin and install the 3rd bolt.
        Tighten the bolts to 25 Nm (18 ft. lbs.).
        1. Tighten the water pump sprocket bolts last. Tighten the bolts to 10 Nm (89 inch lbs.).
        2. Remove the J 43651.
        3. Install the water pump access plate and bolts. Tighten the bolts to 10 Nm (89 inch lbs.).
        4. Install the right hand fender liner.
        5. Install the thermostat housing.
    Aug 29, 2011 | 2006 Pontiac Solstice
    Replacing the water pump on 96 chevy S10,
    Water Pump Removal & Installation 2.2L Engine To Remove:
    1. Drain the cooling system.
    2. Remove fan assembly.
    3. Loosen the water pump pulley bolts.
    4. Remove or disconnect the following:
      • Water pump drive pulley bolts
      • Radiator inlet hose clamp and hose from the water pump
      • Water pump
      • Water pump gasket
    To Install:
    1. Clean the mating surfaces.
    2. Install or connect the following:
      • Water pump gasket
      • Water pump Note: Apply a sealer (GM P/N 12346004) or equivalent to the bolt threads
      • Water pump mounting bolts
        1. Torque to: 18 ft lbs (25 Nm)
      • Water pump pulley and bolts
      • Radiator hose and clamp
    3. Fill with coolant.
    4. Check for leaks.
    4.3L Engine To Remove:
      • Water pump
      • Water pump gasket
    To Install:
      • Water pump gasket
        1. Torque to: 30 ft lbs (41 Nm)
    4. Check for leaks.
    Feb 12, 2011 | 1997 Chevrolet S-10 Pickup
    How long does it take to replace a water pump on Pontiac Aztec?
    It takes near to 1.5 hours to replace the water pump on Pontiac Aztec. The procedure to replace the water pump is as follows:--- Water Pump Replacement ---------
    Removal Procedure :
    1. Drain the cooling system until the coolant is below the level of the water pump.
    2. Remove the drive belt guard.
    4. Remove the drive belt.
    1. Remove the water pump pulley bolts.
    2. Remove the water pump pulley.
    1. Remove the water pump bolts.
    2. Remove the water pump.
    3. Remove the water pump gasket.
    4. Clean the water pump mating surfaces
    1. Install the water pump gasket.
    2. Install the water pump. Notice: Refer to Fastener Notice in Service Precautions.
    3. Install the water pump bolts.
      • Tighten the bolts to 10 Nm (89 inch lbs.) .
    1. Install the water pump pulley. Loosely install the mounting bolts.
    2. Install the drive belt.
    3. Install the water pump pulley bolts.
      • Tighten the bolts to 25 Nm (18 inch lbs.) .
    1. Install the drive belt guard.
    2. Fill the cooling system.
    3. Inspect the cooling system for leaks.
    4. That's it.
    Nov 18, 2010 | 2001 Pontiac Aztek
    How to take off the water punp
    1. Drain the cooling system until the coolant is below the level of the water pump. 2. Remove the drive belt guard. 3. Loosen the water pump pulley bolts. 4. Remove the drive belt. 5. Remove the water pump pulley bolts. 6. Remove the water pump pulley. 7. Remove the water pump bolts. 8. Remove the water pump. 9. Remove the water pump gasket. 10. Clean the water pump mating surfaces. Installation Procedure 1. Install the water pump gasket. 2. Install the water pump Notice: Refer to Fastener Notice in Service Precautions. 3. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.). 4. Install the water pump pulley. 5. Install the water pump pulley bolts. 6. Install the drive belt. Tighten the water pump pulley bolts to 25 Nm (18 inch lbs.). 7. Install the drive belt guard. 8. Fill the cooling system
    Aug 13, 2010 | 2002 Buick LeSabre
    How do you replace a water pump in an aztec?
    Notes Water Pump Replacement
    Removal Procedure
    Jun 17, 2009 | 2001 Pontiac Aztek
    Fisher Paykel EcoSmart GWL15 Logo
    Top Fisher Washing Machines Experts
    Dan Webster
    Dan Webster
    Mike
    Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
