Question about Samsung LN-S4051D 40 in. LCD Television
Same problem... Thanks for the info - I am having the same trouble. When you say 'power board', is this the same as the CCFL inverter? Thanks again, Rob
  • CaptainBanan May 28, 2008
    Thanks for the prompt reply - I will take a look tonight...
  • 558 Answers
No usually the power board and the inverter board are different boards. there are cheap brands that are all in one. so if you only have one board inside the back cover then the answer may be yes, however the power board (section of the main pcb board that supplies power ) is distinctly separated due to heat and has several large capacitors in its section.
Posted on May 28, 2008
  • Scott Hill
    Scott Hill May 29, 2008
    any cap domed or with leakage (color) from the creases indicates bad cap. you cab Google the "capacitor blown image" and that should help you. be very careful and unplug the unit before investigating internal issues.
My lcd tv i purchased 4 years ago is in pure black light, i cant see the picture anymore but i can only hear the audio. what seems to be the problem? thanks
Sir this problem has two possibilities the CCFL or cold cathode fluorescent lamp is already damage or the inverter board is not getting 24 volts supply. Try to check the power supply or use a digital tester to test if there is 24 volts supply to the inverter board if there is a a 24 volts then the CCFL is already faulty or your inverter board is faulty. To be sure try to check also the CCFL if both ends have a burn marks replace it but if no burns, the inverter board is the problem, but be careful when checking this inverter board because it is producing a high voltage and can cause serius injury. If you are not handy in electronic trouble shooting I suggest that you should contact a service technician to do it for you and save you from stress good day and best regards.
Aug 21, 2011 | Samsung Televison & Video
VIZIOP42HDTV10A . It hadn't picture mean black screen , but hear sound from every channel and all another devices input
hi, Your tv has problem with its back light inverter stage. All LCD TV have back light to illuminate the pixels. There are two types of back lighting CCFL(Cold Cathode Fluorescent Lamp) and LED. In your tv its ccfl. As it is ccfl it need a high voltage above 1000v. To provide such a high voltage there will be an inverter stage in all lcd tv with ccfl back lighting. Normally in LCD tvs there will be three boards such as Mother board , Back light inverter board, and power supply. In your tv the ccfl back light inverter stage is faulty. There will in inverter transformers in the inverter board. As it is high voltage transformer there is possibility of its winding get shorted. If so it will drain a high current from the power supply and the protection circuit will shut down the voltage to the inverter board. check the inverter board first. Also there is possibility of bad electrolytic capacitors in the inverter board will lead to this type of problem. First of all check the supply voltage from the power supply to the inverter board. Change the electrolytic capacitors in the inverter board and in the power supply stage. If the problem is not rectified then you have to replace the inverter board. ok
Jun 10, 2011 | Vizio P42HD Television
The monitor is going down. If I take out the current and put it back then it works but only for a limited (irregular) time then shutting down again
You may have a faulty inverter board or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. Usually the CCFL lamp fails before the inverter.
The inverter board can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Jul 07, 2010 | Compaq FP 7317 17" LCD Monitor
My monitor keeps going on and off. It will be off
You could have a faulty inverter board. The inverter supplies high voltage to the CCFL lamp/s, these lamps are mini fluro tubes approx 1,5mm dia. and the length of the screen.
Check the inverter output/inverter board and you maybe able to get service, parts and DIY info from
www.lcdparts.net
Dec 13, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
My delle173fpc powers up then goes dark if i swittch it off then back on it will come on for a few seconds then go dark again
You could have a faulty inverter board that supplies high voltage to the CCFL lamp or a faulty CCFL lamp.
Check out LCD Parts for service, parts and DIY info. click on this link to their WEB site :-
www.lcdparts.net
Nov 05, 2009 | Dell E173FP 17" LCD Monitor
We r using dell lcd 1901fp when we power on it displays for 2 sec and then disply off but power led shows on, again we poweroff and on it it shows for two sec again disply disapper kindly suggest exact...
You could have an inverter board problem. The inverter supplies high voltage to the CCFL lamp which provides the back-lighting.
For service. parts and DIY info check out LCD Parts - click in this link to their WEB site : -
www.lcdparts.net
Oct 16, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Dell E153FPc switches off (black Screen) after a few minutes. If you switch it off & back on again it will stay on for a few minutes, then go off again.
www.lcdparts.net
Oct 16, 2009 | Dell E153FPc 15" TFT LCD Flat Panel...
Acer al1716 dont work
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Sep 03, 2009 | Acer AL1716 17" LCD Monitor
Philips 190B - flickering screen
Its looks that Inverter board not work well for CCFL cus a CCFL inverter is a device (an inverter) for providing drive power to a Cold Cathode Fluorescent Lamp CCFL
Jun 17, 2009 | Philips 190B6CB/27 19" LCD
Sceptre X9G-Komodo IV
I recently came accross one of these monitors (Planar PE191M) with the identical issue. The resolution was to replace the two 470ufd 25V capacitors that are located on the main power board. The main power board also contains the audio circuit and more importantly the inverter circuit that drives the CCFL backlighting. The suspect caps were identified using an ESR meter; if you happen to have one of these meters you can confirm this is the issue with your unit(s), alternatively you can just replace the two capacitors and see if it resolves your issue. Hope this info helps someone out there.
Sep 05, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Samsung LN-S4051D 40 in. LCD Television Logo
65 people viewed this question
Henry  Thomas
Henry Thomas
