Question about HP LaserJet 4200dtn Printer
Always need the paper manuually feeded - HP LaserJet 4200dtn Printer
  • 150 Answers
It's a computer setting I think.
Posted on Oct 05, 2010
Always paper jam error on my cannon 3530
Check for a paper fragment at either end inside the printer chamber or underneath the paper feed roller cover plates. Anything that holds a paper feed sensor arm open will give you paper feed errors, and they can be remarkably small.
May 14, 2015 | Cannon Office Equipment & Supplies
Lexmark e232 The automatic feed has stopped operating and I get a "paper default" light button. I can't findf a paper jam. The system refuses to pick up the sheet and feed. Where else...
Just power down the printer. This should resolve the issue.
If you need further assistance, please contact Lexmark Technical Support Center.
Jun 13, 2011 | Lexmark E232 Laser Printer
Feeding paper: how to fix the automatic feeding from the tray? I think the printer won't pick up the paper from the tray. we always have to manually feed the paper. How to fix it?
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Dec 13, 2010 | Xerox DocuPrint 203A Laser Printer
The paper alwayes jamming
If paper is consistently jamming, there are two usual suspects: worn feed rollers or a physical obstruction. If the paper comes out with a crease or dog-eared corners, you most likely have some sort of debris blocking the paper path. However, if the paper doesn't have any creases or bends, then the feed rollers have most likely worn out or need to be cleaned. For obstructions, I would suggest manually feeding a thick piece of card stock through the machine in hopes of clearing out any debris or stuck paper bits.
-David.
Nov 02, 2010 | Office Equipment & Supplies
I checked the steps on your Epson R340 Paper Feed problem. Both of our R340s are about a year and a half old and they are both having the same problem. There is nothing wrong with the paper . . . it...
hello, eventually the feed roller will need to be cleaned, it collects paper dust and dust and inks, so becomes smooth, and unable to grab paper properly, cleaning with alcohol, yes it does clean but dries rubber, WD-40, is waht i use, but i allow it to be absorbed into roller, then wipe off the excess, then try feeding paper.
Oct 14, 2010 | Epson Stylus Photo R340 InkJet Printer
Paper doesn't always feed, and when it does, the paper rolls through without printing
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
May 16, 2009 | Epson Stylus Photo R1800 InkJet Printer
Printor indicator brinking and paper light is always on
Printor indicator light is brinking and Paper indicator light is always on and never disappear even if I feed the paper and push the paper button
Nov 16, 2008 | HP Business Inkjet 1000 - Printer - colour...
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
HP LaserJet 4200dtn Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
