I have telemann washing machine. It needs a new agitor part for inside the washing manchine. the model is CA09Z0E0300 please could you tell me how much this would cost .i am in new zealand
  • 38 Answers
SOURCE: hoover 5kg washing machine
sounds like a spring which keeps the tub centred is broken. Could also be a worn bearing. this needs specialised tools to get the problem fixed, especially to replace the bearing. contact a repair-person.
Posted on Jun 15, 2008
SOURCE: Plastic screen on door cracked,
hi there, i had the same problem.. did you manage to get a replacement, if so where from?
Thank you
Regards
Asad
Posted on Oct 13, 2009
  • 11 Answers
SOURCE: washing manchine water overflowing over the top
where the hoses go into the machines you will notice those valves are controled by solnoid switch thats what starts and stops water flow as you turn selector knob you should hear them click if that turn off water supply remove hoses from back of machine check if filter screen is in place and that there is no trash keeping valve open p.s switch from hot and cold to see which one needs to be replaced or repaired
Posted on Apr 08, 2010
sonicboomele
  • 1557 Answers
SOURCE: Maytag washing machines and Dryers replacement keys.
hi henry i do a lot of repairs here in australia for maytag and clean maid but they don own me so ill let you in on a little secret they don want you to know. there barrels are around $ 170.00 fitted but your local ( good) lock smith can replace them for $ 40 approx as for servicing dont look to maytag they will send you broke almost all good washer techs know how to service maytag machines just shop around for an honest one
cheers ever need any further advice feel free to email me
sonicboomelectronics@hotmail.com
kirk a manager
Posted on Jul 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: how to remove an agitor from a hotpoint washing
The following advice is for replacing the “Agitator Dogs” on TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Telemann model xqb60-803clps. Why is it displaying E2?
From what I've been able to find on the net, the E2 error code means there is a problem with the drain pump. Is your machine draining properly or is there water left in the tub? The drain pump might be partially clogged and taking too long to drain out the water--start there first.
Nov 05, 2015 | Washing Machines
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
Washing manchine water overflowing over the top
Nov 19, 2009 | Frigidaire GLWS1339CS Top Load Washer
The agitor is locked
Try unpluging the maching then start the wash from the the start. Here is the manual.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/8566930.pdf
Aug 12, 2009 | Whirlpool Washing Machines
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
How do I replace the dog agits on a Kenmore model # 92597200? I have the agitor out of the machine but I need to know how to get the dog agits out.
pull your top and bottom of the agitator apart then the holder for the dogs should fall out when you turn it upside down
Jan 07, 2009 | Kenmore 24902 Top Load Washer
My manchine won't fill with water.
hi
it sounds like a faulty water valve, one way to check that is to connect the hot water hose to the cold tap and select hot water not cold and see if it fills if it does than it is the cold water valve faulty
cheers grant
Aug 27, 2008 | Fisher Paykel EcoSmart GWL15
Old sewing console with new machine
not without a cibnet maker, too expensive with
Aug 12, 2008 | Necchi 3101 Mechanical Sewing Machine
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
