Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
I was removing hair from the rotating brush at the bottom after removing the cover and the end away from the belt slipped out. I have the belt in proper placement but can't seem to fit the entire piece back in place. Is there something I am missing? Please help!
  • 377 Answers
Sounds like you are having difficulty stretching the drive belt so that the roller end clip can be slid into place.
The end clips on the roller brush are keyed so they can only go into the retainers one way. Remove the belt and check to see what the orientation of the end pieces should be in order for the brush to seat on the vacuum body and mark an alignment if necessary. Remove the brush, add the belt and replace the brush in the vacuum with the roller retainers in the proper position. You may have to stretch the belt a bit, but it should fit in.
Posted on Oct 05, 2010
Testimonial: "Thank you very much for your prompt, helpful response!! I have it working great again!"
  • pwillitz Oct 05, 2010
    THANK YOU for your great rating.
    I am glad I was able to be of assistance to you.
    Be well.
    Paul
Electrolux Z61a brush not rotating
There should be a rubber belt somewhere along that roller, probably in the middle, behind the bottom cover plate, Remove the plate. That belt may have just slipped off the motor shaft, but it may be broken.
The belt could possibly be installed in either of two ways. The motor shaft is not parallel to the beater bar (brushes), so the belt must twist to wrap around both the motor shaft and the beater bar. If it's twisted one direction, the beater bar will rotate the correct direction (as if drying to pull the vacuum forward). Twisted the wrong way, it'll rotate the opposite direction. Try it one way, then bump the power switch to verify that the brush is rotating the correct direction before putting the bottom cover plate back on.
Aug 10, 2014 | Electrolux Vacuums
Spinbrush not working on eureka as1104
If the belt is intact, the brush roller ends may be so jammed (usually with hair) that it cannot rotate. Also, if the brush roller cannot rotate, the motor shaft may be rotating in one spot on the belt and eventually will burn it out. The solution in the case of the brush roller is to remove it and check for free rotation. If the ends are binding, the brush roller will have to be disassembled to remove debris.
Aug 10, 2014 | Eureka Vacuums
Brushes not rotating on kirby vacuum
Change the belt, they stretch after while. If it made a burnt rubber smell or it's > 1 year old this is probably your problem.
Here's what you need:
http://www.vacuummedic.com/product.php?id=279
Good Luck!
Vac Dr.
Oct 15, 2012 | Kirby G4 Bagged Upright Vacuum
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
My powerhead drive belt to the N137A electrolux model has broken. I have a new belt for replacement but do not know how to install.
Turn the PN bottom up. With a Phillips screwdriver, remove the six screws in the base. Turn PN over and lift back of cover, then gently manipulate it until it comes off.
Slide the belt off motor shaft, if necessary. Remove the screws on each end of the brush and lift the end of the brush so you can remove the belt, if necessary. Place new belt on brush and place brush into slot. Replace screws and tighten. Pull belt back to motor shaft and slip on. Check belt for tautness. There should be a little play, but not much. Make sure belt is placed correctly and rotate brush a few turns.
I recommend cleaning the inside of the PN while you have it apart. Use the dust brush to vacuum as much as possible out.
Make sure the light cover is in the correct position. Carefully place front lip of PN cover into slot in front.of the PN. Carefully settle cover in place. Check around the PN to ensure cover and base are correctly placed. Turn PN over and replace screws, short one in front.
I do recommend letting a trained Aerus Electrolux tech do this, especially since the belt will have a one year warranty if he/she does it. Of course the belt should last longer than that, anyway.
Mar 03, 2011 | Electrolux Epic 6500 Vacuum
Beater bar belt install
  • 1
    Unplug the vacuum cleaner and turn it upside down, flat on the floor, with the roller brush facing up.
  • 2
    Remove the the bottom cover plate from the vacuum by prying it off gently with a screwdriver blade. Set aside the cover plate.
  • 3
    If the old belt is broke, remove it by pulling the belt from underneath the roller bush. If the belt is not broken but simply worn out, and is still attached, cut it off with scissors.
  • 4
    Remove the roller brush by lifting both ends from the grooved slots in the housing of the vacuum cleaner.
  • 5
    Cut away hair, thread, string and other debris wound around the roller, using the scissors. Tangles on the roller brush are a common reason for belt wear and breakdowns due to the added weight and stress on the roller brush.
  • 6
    Slip the replacement belt over the roller brush and seat the belt in the groove in the center of the roller.
  • 7
    Slide the roller brush back into the grooved mounts on either side of the housing and snap into place.
  • 8
    Pull back on the new belt and slip the loop over the pulley attached to the vacuum motor.
  • 9
    Replace the bottom cover by snapping it back on the housing until it clicks into place.
  • Feb 16, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
    Brush will not rotate
    You probably have a broken brush belt. Unplug the vacuum and turn it upside down. Remove the cover over the brush, sometimes with simple push clips or screws and find the belt. If the belt is there but broken or worn out, take it with you, and the model number of your vacuum to buy a replacement belt. While you have the brush out, clean the ends where it is held in place in the bottom. Many times a lot of dirt and hair gets trapped in there, preventing the brush from spinning.
    Dec 19, 2010 | Bissell 5770 Healthy Home Bagless Upright...
    Brushes don't spin
    Remove the bottom cover and replace the broken drive belt. Check that the brush will rotate freely--likely everything is jammed with hair and dust. The brush assembly should just lift out of the case and the end bearings will pull off. The brush needs to be removed to install a new belt anyway. There should be a diagram that shows how to install the belt (it has a half-turn twist).
    Jul 15, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
    No suction
    Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
    Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
    Remove hair from brush roll using scissors.
    Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
    Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
    Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
    If its stiff to rotate you will need new roller.
    Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
    Now check the long flexi hose & metal wand for any obstructions.
    If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
    On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
    Chris...
    Sep 24, 2008 | Dyson DC07 All Floors Bagless Upright...
    Brushes don't spin but it still has suction
    The brushes are usually connected to a motor by a rubber belt. These can wear out and snap (particularly if the brushes are clogged with hair). Usually the bottom of the vacuum can be removed by undooing a few screws and gently pulling it downwards. If the bottom doesn't want to come off, hunt around for any screws you may have missed - the designers seem to think it's funny to hide them. Once the bottom is off, check the belt and remove any hair wrapped around the ends of the brush bar. If the belt is broken you will need to find a replacement.
    Apr 23, 2007 | Hoover SteamVac F5914-900 SpinScrub...
    Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
    354 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
