Question about Perstel Symphony4U MP3 Player
My Symphony4U MP3 play crashed, and lost the installation CD also, does anybody have the installation CD? or the firmware code for share?
Lost install cd how do i download one?
Try downloading and installing these drivers:
http://drivers.softpedia.com/get/FIRMWARE/Iriver/Iriver-iFP-89-0UMS-firmware-128.shtml
Most newer operating systems will be able to recognise the device once you have the correct drivers. Hope that helps!
Feb 14, 2010 | iRiver iFP-890 MP3 Player
Philips gogear 4GB
Universal support for Philips SA60:
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=ENG&searchtxt=SA60
Select your model from the page above.
On the page of the model select > Software & drivers on the left side.
Available:
  • "Media converter software" for the computer.
  • "Firmware" and "firmware updater" for the player
(check the release notes and installation instructions before downloading)
Sep 17, 2009 | Philips GOGEAR SA6045 MP3 Player
Rover 25 CD player wont play MP3 format discs
It sounds like your Rover dosn't have MP3 capabilities. You will have to use standard audio CD format (not data/MP3 format). You will only be able to burn about 15-20 songs but they will play in any cd player.
Aug 07, 2009 | Car Audio & Video
Starting up missil flash MP3 player
You can use your mp3 without the software. When you plug it in, it will ask you if you want to install drivers. Click "no" and open the player as you would a flash drive. Drag and drop your favorite tunes and it should work fine.
You will need the software for firmware upgrades, voice recording, and other advanced features, but most of the function does not depend on installing that disc.
Feb 03, 2009 | Aiwa HZ-WS2000 MP3 Player
Im having plently of trouble with Tiny Tunes.
I had a similar problem. My black tinytunes locked up from static electricity. Even after resetting, it would would freeze up whenever I tried accesing any menu item.
The fix can be found on the Brookstone installation CD. It's a blue, 3-inch disc with "Brookstone" on it. Put it in your computer's CD ROM and it should autoinstall the SigmaTel Audio Player. You may get prompted during installation that some files on your computer are newer than those on the disc. Choose to keep the newer files if this happens.
After the install, connect your TinyTunes to the computer. If you can, copy any files from the player on to your PC as they will be erased in the next step.
Now look for the SigmaTel MSCN Audio Player folder in your program files. Click on "Firmware Download" within. A window will pop up showing the firmware versions. Tick the "Format Data Area" box, then select "Yes" when prompted. Now hit "Start" at the bottom of the box.
At this point, a couple of blue progress bars will run for about fifteen seconds as the firmware loads. When it's finished, hit "close".
You're done !
Peace.
Marco
Mar 07, 2008 | Brookstone TinyTunes MP3 Player
Iriver h10 (5gig) not playing music (firmware 2.53)
install version 2.51 firmware and run mtp updater this can be found on iriver site www.iriver.com-support-ask.asp
Jan 21, 2008 | iRiver H10 MP3 Player
[zen V+ 1Gb] zen won't allow me (crash) to upload further a certain storage size
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
Aug 26, 2007 | Creative Labs ZEN V Plus MP3 Player
Vm9510 wont play cd/mp3 formats
Does it say it will play MP3 somewhere? This is a recent innovation with CD players Regular players do no include MP3 in the firmware.
Jun 16, 2007 | Jensen VM9510 Car DVD Player
Fuzzy noise
My MuVO TX was having problems until I installed the latest firmware. The last firmware release was in March 2007. If you haven't updated the player's firmware since then, try downloading it and installing Creative MuVo TX FM Firmware 1.24.02.
Jul 16, 2006 | Creative Labs Nomad MuVo TX MP3 Player
Perstel Symphony4U MP3 Player Logo
23 people viewed this question
Top Perstel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Perstel Audio Player and Recorder Expert? Answer questions, earn points and help others
