Question about Compaq Presario Notebook
Compaq presario notebook computer
Can the compaq presario notebook be used overseas at 240 wattage?
I noticed on the plug that is says 100-240 with 50-60 hz.
Thanks for your help
Shirley
    Scholar:
  • 110 Answers
Yes it can.
All notebooks that have dual voltage power supplies can be used worldwide. With the correct physical adapter plug, you need not worry about plugging it in, it will automatically detect the 240v three phase power used in the UK and configure itself to supply your laptop with the usual amount of power automatically.
Posted on May 28, 2008
How can I find out how many watts my System Model DA238A-ABA 6450NX NA910 use in 1 hour? (compaq prisario)
Compaq Presario 6450NX Desktop PC?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpb11683&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=240121
Power Supply - 200 Watts
That is the supposed Maximum Wattage the computer will use per hour.
Variables come in to play, however;
1) Back when the computer was made, the Power Supply manufacturers were 'fudging' the real maximum rated Wattage.
True ratings were more like 60 to 70 percent, of what was actually stated.
Divide 200 by ten; take it times;
6 for 60 percent. 120 Watts
7 for 70 percent. 140 Watts
So, the Actual Maximum Rate Wattage, could be as little as 120 Watts, or a little more than a 100 Watt light bulb.
2) Second variable is what is the computer being used for?
Surfing the internet? About 100 Watts.
Playing an intensive game, (Yeah right. Not on that computer), or using an intensive program?
Then, you may be using the Maximum rated Wattage,
120 to 140 Watts.
So,........the hourly wattage rating, could be as low as 100 Watts per hour, or perhaps up to 120 to 140 watts per hour.
Also include the power used by the monitor.
If you do not have the specifications of the monitor, see if you can look them up online.
My HP 2009M uses 47 Watts, (2 Watts when in Sleep Mode),
http://www.newegg.com/Product/Product.aspx?Item=N82E16824176112
My other monitor I use (Dual monitors), is an RCA 26 inch HDTV,
(RCA L26HD31)
Uses 82 Watts,
http://reviews.cnet.com/flat-panel-tvs/rca-l26hd31/4507-6482_7-33346932.html
(And the power supply for my computer is 500 Watts.
Hmmm,............no wonder the little wheel spins so fast in my electric meter! lol!)
Add the two together to get a basic conclusion, of what Wattage per Hour your computer system is using.
Don't forget to include printer/scanner/fax machine/copier, WHEN being used.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 04, 2013 | Computers & Internet
System failure in my laptop ??
Remove the battery from the computer and plug in the correct charger and see if it will power on. without the battery. if so turn off and put battery back in with power connected see if it powers up.
Oct 29, 2007 | HP Compaq Presario 730US Notebook
Want to know power consumption of a hpsr5410f
The HP Pavilion w1907, 19 inch Widescreen monitor, RK283AA,
uses 49 Watts in operating mode, 2 watts in sleep mode.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00916924&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3351967
The Compaq Presario SR5410F Desktop PC, has a 250 Watt power supply. (Maximum wattage rating )
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01374067&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3686678
Theoretically.
Back in the day when this computer was made, Power Supply manufacturers were 'fudging' a bit on the truth.
(HP has their Power Supply's made by another company.
Bestec, HiPro, and Delta, are three of them )
Actual wattage is more like 60 to 70 percent, of what is stated.
250 divided by 10 = 25.
25 times 6 = 150 (60 percent)
25 times 7 = 175 (70 percent)
Your Power Supply's actual maximum rated wattage, may be as low as 150 Watts!
Going with the Power Supply produces a maximum of 250 Watts;
If you are playing an intense game, or have several programs running at once, you MAY reach using 250 Watts.
Just surfing the internet? About 100 Watts.
Desktop PC plus Monitor:
1) Surfing Internet: 149 Watts, or let's just say - 150 Watts
2) Computer is maxed out running hard?
249 Watts, or let's just say 300 Watts.
Voltage times Amperage = Wattage
Wattage divided by Voltage = Amperage
Number 1 above? About the power it takes to use a 100 Watt light bulb, and a 50 Watt light bulb. (Incandescent)
Number 2? About the power it takes to run three 100 Watt light bulbs.
(Incandescent)
Regards,
joecoolvette
Apr 16, 2012 | HP SR5410F 18GHz Presario Pentium Desktop...
Can I plug my laptop into 220V 50 Hz power system?
Look closely at the Power Pack.
My Dell says 100-240 volt
That's what you want to see.
Aug 20, 2011 | Compaq Presario CQ62-215DX Laptop
I have a GR-30 George Foreman Grill. I brought it overseas, and I need a transformer to accept the 240 VAC local voltage. Do I really need a transformer that handles 1400 W? That's what the label...
Hi there.
You really have to use a transformer of that rating if that is the unit's requirement. You can use a higher wattage but definitely, do not use a lower wattage rating.
Regards.
Jul 19, 2011 | George Foreman GR30 Indoor Grill
Describe your compaq presario cq60 touchpad not
after rebooting my Compaq Presario CQ60 laptop the touch pad does not work and I have to use a plugged in a mouse
Mar 09, 2010 | HP Compaq Presario CQ60-249US Notebook
I cannot find the right driver of Ethernet Controller for my Compaq Presario C700
Hi there.
Go here, choose the correct model because there six C700 models and download the drivers you need:
http://h20180.www2.hp.com/apps/Lookup?submit.y=0&submit.x=0&lang=en&h_client=S-A-R135-1&cc=uk&h_query=presario+c700&h_page=hpcom,igmx&h_pagetype=s-001&h_cc=uk&h_lang=en
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Compaq Presario 700 470024-192 Notebook
I just need to know if these computers have a built-in ethernet card installed or do I have to buy one seperately. Compaq Presario 1800 Notebook.
Yes this laptop has a built in 10/100 Ethernet port allowing you to go on the internet with a direct cable from your Modem/Router. Most laptops, and even computers nowadays come with a built-in ethernet port.
Jan 28, 2009 | Compaq Presario 1800 Notebook
Partition not 100% on laptop 700 presario
From the description loo\ks like it's not a partition problem, but the Compaq CD.
Try to partition Hard Drive using Windows 98 bootable CD.
Try to install Win XP from different CD - doesn't have to be Compaq. Later you can download drivers.
Dec 27, 2008 | Compaq Presario 700 470024-192 Notebook
Overseas Use
Yes. The power supplies and battery chargers supplied with all Powershot Digital Cameras are designed to work on input voltages from 100-240 volts (50/60 Hz). The only item that you may need is a plug adapter that allows you to plug the U.S. type power supply or battery charger into the foreign type wall outlet. Plug adapters should be easily available at a local electronics store.
Aug 31, 2005 | Canon PowerShot S10 Digital Camera
Compaq Presario Notebook Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
