Question about Panasonic Televison & Video
My n2qayb remote just stopped working . I don't know what I pressed. I put brand new batteries and still isn't working! Help it's only 10 months old.
MY PANASONIC REMOTE STOPPED WORKING I WAS JUST ABOUT TO BUY ANOTHER FROM AMAZON BUT DECIDED TO SPRAY THE FACE WITH CONTACT CLEANER WIPED IT CLEAN AND IT WORKS A TREAT. I SUPPOSE WD40 WOULD DO THE SAME. PAUL
Posted on Dec 27, 2013
SOURCE: remote control not working properly
Try cleaning the contacts that connect to the batteries. A pencil eraser will clean the contacts.
Posted on Jan 27, 2010
SOURCE: RCA Universal Remote stopped working
I also have the same problem with my rcv remote and it started when the batteries accidently feel out
Posted on Feb 05, 2008
SOURCE: A few months ago my dish remote got real hard to
Again if you are using a dual receiver point the remote actually touching something on your body instead of pointing it at the tv.
Posted on Nov 01, 2009
  • 23 Answers
SOURCE: my remote for the harmony 550 says welcome to
First I would check to see if any of your buttons are sticking. I have found that this is a common problem with the 550 remote. I really like this remote but if nothing works check your buttons to see if any are pressed under the plastic. This remote can only work one button at a time so if one is being pressed it will not work.
Posted on Dec 11, 2009
SOURCE: Code list
I have the code list. I'll have to scan it to put it on. But does it work? None of the codes worked for me.
Posted on Jun 11, 2010
Panasonic n2qayb
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Mar 24, 2014 | Panasonic Televison & Video
Remote control car parts
You may need to reprogram the remotes.
1. Turn ignition to run position (as far as you can go without starting engine).
2. Using any Working remote, press the UNLOCK button for 4 to 10 seconds.
3. Within the specified 4 to 10 seconds, continue pressing the UNLOCK buton and press
the PANIC button for 1 second and release both buttons at the same time. A chime will
sound within 3 seconds to indicate that the vehicle has entered remote programming
mode.
4. Within 30 seconds of the chime, press any button on all remotes to be programmed
including previously programmed remotes. A chime will sound after each remote is
programmed.
5. Turn ignition to OFF and remove key.
6. Test all remotes.
Aug 12, 2013 | Chrysler New Yorker Cars & Trucks
I have a hampton bay remote that just stopped working. I have installed new batteries, have checked the code with another remote so I know the problem isn't the fan. The light on the remote does not...
If the light on the remote is not lighting when you push a button, check the batteries to make sure they are in the proper position. If one is turned the wrong way, the hand held will not work. You may also want to check the replacement batteries to make sure they are fully charged. If all this fails to solve the problem, you will need replace the hand held remote. Since Hampton Bay Fans are a house brand for Home Depot, they stock and sell replacement hand held remote controls.
Hope this helped you. Please let me know. Thanks.
Jul 13, 2011 | Hampton Bay Heating & Cooling
Code list
Mar 02, 2009 | Universal Remote Control Battery Free...
Wii Remote stopped working for no reason.
Well, pressing 1 and 2 doesn't work if your Wii remote came desynched. Press the Red Synch buttons on both the Wii console (located under the SD card flap) and the one on the back of the Wii remote, and hold one then the other for about 5 seconds. Should help.
Jan 19, 2009 | Nintendo Wii Console
Handset doesn't turn on; press a button, beeps and turns off
from a different brand portable phone - - it worked for me! "If you experience difficulty with placing/receiving calls, a lost security code may be the problem. The handset cannot communicate with the base. Unplug AC adapter. Disconnect handset battery for 10 seconds. Reseat the battery and then place in base. Replug AC adapter."
Oct 22, 2006 | Panasonic KX TC901W Cordless Phone...
Televison & Video Logo
1,301 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
